shifting the t56
Car: 73 chevy truck
Engine: 406 11.6 comp 2.02 heads
Transmission: stock th350
shifting the t56
whats the best way to shift the t56 when racing. can you just slam the gear into the next with out touching the clutch? how strong are the viper t56`s? i already blew up a 700r4 the first day i had it
Car: Third gen of course 83 Z28 CAMARO
Engine: LG4 305 V8 4 bbl
Transmission: T-5 (5-SPEED)
NO you gotta cluch but the way i do it when i race is pull on the shfter as you start to cluch and start to relese the cluch as you start to hit the gear you get the firmest shifts that way
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Re: shifting the t56
when we went to vegas for new years 2004 we rented a viper and he drove it. he was surprised at how close the shifts are as compared to a super t 10. But he got the hang of it after about 100 miles.
Car: 73 chevy truck
thanks for the help. i am planing on doing the swap with a viper t56. i fould a place that make an adapter plate and sells the trans mission with it for 2499.00 it also has a mechanical speedo. you guys might of heard of them ddperformance.com there in a bunch of chevy maganzines.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if the trans doesnt want to go into the next gear, theres a REASON for that.
when drag racing, i do a very quick push of the clutch as i shift, enough to get it in the next gear. i also release extremely quick, but SMOOTH... this makes it so i dont break them loose on the 1-2 shift and spin halfway down the track.
when road racing, i shift the same, but with even more emphisis on being smooth. on the downshift i usually only clutch enough to bearly disengage, then i match revs as its slipping in the next lower gear... done right, its absolutely smooth and you feel like you accomplished somthing.. done wrong, the rearend jerks and you look like you just got a manual trans yesterday. lol
I hope you aren't full throttle shifting that poor manual either, you're going to end up HAVING to buy another tranny.
however, if you want to just slam it into gear get an automatic 700R4 build the tranny so its indestructible and throw a B&M shift kit on it so you can just ratchet into the next gear.
Car: '90 RS
Engine: 377 LSX
bigjay89gta
Oct 15, 2015 08:04 AM
