best way to hook up a tranny cooler
Car: 85 z28
i live in orlando/ kissimmee FL, average temp is 90 everyday should i run it jus strait to the cooler or thru the rad then cooler, also car runs about 220 in this heat so any suggestions
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'd probably do it through the rad and then the cooler, or think about bypassing the rad altogether if the cooler was big enough.
"from the trans to rad to cooler then back to trans, might want to consider a remote filter while you're doing it."
How does that work? Run the hose infront of radiator? Then into the trans cooler then back to trans? With a filter somewhere on the line so easy cleaning? Im confused about that a bit. sorry.
Engine: 383 Carb
Transmission: 4L60
Disconnect the upper line to the radiator, run a line from the port on the radiator to the cooler, and then another line from the cooler back to the factory line.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
