i have an 3.08 posi 28spline axle.
the only gears i can find for a 10bolt 7.5" are for a 27spline.
anyone know any sites that sell 3.73's for my vehicle? (2-series btw)
All 7½" 10-bolts have 27 splines on the pinion.
That has nothing whatsoever to do with the number of splines on the axles.
DON'T BUY the special gears. It WILL come back to bite you in the posterior someday. Buy regular gears and a spacer instead.
http://www.drivetrainspecialists.com...=28&cat=GM+7.5 is one that has just about anything you're likely to need.
ok now im really confused.
basically, all im looking for is 3.73's and appearently a spacer now? anyone provide a direct link to what im looking for since i have no idea whats going on now
This is going to be complicated, so write it down, or get professional help, or whatever.
Click on the link I posted. On your browser's menu, go to Edit, Find on this page, and type in "spacer", and press Enter. Magical things will happen.
five7kid
close
Because if you use them, and then you come up with a 3-series posi (the SLP one for example) later on, you won't be able to use them. You'll have to buy and set up gears .... again.
They work fine, as far as working goes; but it seems like everyone I've ever known that used them, found themselves stuck having to buy regular ones sooner or later to replace them, when they wanted to make an upgrade.
five7kid
close
Does SLP even have any more of those take-off posi's left? Last I heard, they only had the "upgrade" new off the shelf units.
Other brand posi units are available in 2-series.
Of course, that could be handled by upgrading with a 3-series posi carrier when the gears go in.
Quote:
Originally posted by five7kid
RB, what's wrong with the 2-series gears?
http://store.summitracing.com/partde...ew=32&applid=%
thanks for the link, thats what i looked at, but when i saw 27spline, thats when i said forget it, because i thought mine was 28spline.. with those gears do i still need a spacer?Originally posted by five7kid
five7kid
close
Quote:
Originally posted by TraviZ
...with those gears do i still need a spacer?
No.Originally posted by TraviZ
hey thats cool. so basically, i just need to buy that, the install kit, and take it to my local favorite shop and tell them have fun?
Well you already have a posi, so you're not in the market right this minute; what about tomorrow? Do you want to be stuck with having to find a 2-series posi (very difficult to come up with in an actual performance part, "2-series" not being a performance part spec in the first place); or would you not rather be able to use any posi you find? The difference in price is about $30 total. For $30 added to a job that's going to cost you about $800 by the time you're done with it, you can future-proof yourself. Pretty cheap insurance in my book.
RB,
thats this one: IK83-0750 GM 7.5 RING GEAR SPACER DTS 55
not this one: IK4111 GM 7.5 SOLID SPACER 18
correct?
correct?
ii dont want to upgrade my rearend agian till it breaks from too much power coming from my lo3
Yes, the one called "ring gear spacer".
The other one is the solid spacer with selectable shims, that replaces the crush sleeve.
Lots of spacing going on...
