question about computer
Car: 86 trans am
Transmission: T 56
I have a 86 trans am with the stock tpi on a 350.
It has a 700r4 with the electronic pick up .
My question is does the speed sensor send a signal to the computer or the speedo or both?
And if the computer does get this signal with a t56 swap will the SGI 5B box provide me with the proper signal?
Thanks for any response.
Transmission: 4L80E/4L80E
If the VSS is located in the tranny, it sends the signal to the ECM, and the ECM then "runs" the speedometer.
Check the stickies. I believe the T-56 uses a different pulse count system.
