9 bolt brakes??
Old Jun 28, 2004 | 03:45 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
9 bolt brakes??
Does any one know where to get the whole brake set up for a 9 bolt rear end? and how much would it be for everything? i checked all the parts stores around my area so im guessin i have to get them off line. any help would be great, by the way i need disk. THANKS
Old Jun 28, 2004 | 07:52 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
I woudl think you best bet would be to check out some junk yards. You might even want to pickup the whole rear axle so you can get everything you will need off of it.
Old Jun 30, 2004 | 02:45 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
By whole brake setup do you mean everything including mounting brackets and all? Ordo you just need calipers, rotors and pads? If its the later parts stores should have them. I have never had such a problem. If you need a the brackets and all you may be able to get them from 9-bolt.com or as said before, from a junkyard.
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
