vehicle speed sensor (help)
Old Jun 28, 2004 | 04:58 PM
88gtatransam's Avatar
Car: 1988 Firebird Trans Am GTA
i have a 1988 trans am gta 305.... when i got the car the speed sensor wasnt reading the speed of the car. So i changed the sensor it self and the gear also, and its still not working..... What eles could be done so i know how fast im going
Old Jun 28, 2004 | 09:51 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You can look at your tach. Your speed is directly proportional to the engine rpm and gear your in.
A better suggestion would be to check the wiring thou. Do you have a check engine light or is the speedo just not working?
Old Jun 29, 2004 | 05:12 AM
yeah the check engine light is on.... so what should i do next...
Old Jun 30, 2004 | 11:44 PM
dankhound's Avatar
Car: 91 RS
Pull the code using the paperclip method. If its a vss code you have a problem in the wiring between the buffer box and the sensor. If its not a vss code your problem is between the buffer box and the speedo with the speedo being a possible culprit.
Old Jul 1, 2004 | 01:51 PM
ight thanks ill check that out
Old Jul 1, 2004 | 03:29 PM
CamaroEFI's Avatar
where is the buffer box?
Old Jul 1, 2004 | 03:34 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
There's a thread in this forum on page one at present which deals with this exact subject. Do a search.
Old Jul 1, 2004 | 07:28 PM
so if my VSS buffer box isnt working right, my speedo wont show me the speed of my car.... so how do i check it, and how do i replace it if its bad... (sorry... im new to the third gen cars)
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
Infested
May 22, 2018 11:56 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
GVMV
Aug 16, 2015 08:01 PM
