Aluminium driveshaft problem
Old Jul 5, 2004 | 09:21 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Im trying to match up this driveshaft (off a 2000 Z28) to my stock yoke. I had the Ujoints replaced on the DS, and the yoke doesnt want to seat the DS (because of the clips being in the way). Is there a specific yoke I can get that will help (one off a 2000 Z28?) or am i going to have to get new u joints?
Old Jul 5, 2004 | 09:33 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
visual
Old Jul 6, 2004 | 11:17 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The u-joints are the problem.. The driveshaft I took from a 2000 Z28 fit perfectly (the yoke is the same as our cars)..
Old Jul 6, 2004 | 11:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Squeeze the end caps together with a pair of channel locks or something to compress the grease seals.
Looks to me, just looking at the difference between the 2 grease seals in that pic, like the cap that's to the right in the pic has a roller that's come out of its place where it goes and is laying in the bottom of the cap, and it's keeping the cap from going on all the way.
Old Jul 6, 2004 | 11:57 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
mine fit like that too. i just put the caps on and torqued em down. i think maybe the grease caps are a little bigger
Old Jul 6, 2004 | 07:18 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
I havnt put it all together, but I did get the yoke and driveshaft to fit together, but just BARELY. So I hope they will continue to stay together.
Old Jul 6, 2004 | 08:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Did you check to make sure the rollers are all in place?
If they're not, you'll be back right where you are now, except a little poorer.
Old Jul 10, 2004 | 12:29 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Thanks for all the help. Its all back together. Iv driven about 100 miles, most 80mph on the interstate, and I see no leaks yet (although all of a sudden 1-2 gear shift is slow. 3-4 shift always has been...)
db057
Apr 28, 2019 07:45 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
