screwed something up..
Old Jul 6, 2004 | 02:10 PM
CamaroRS385hp's Avatar
Car: 1987 Iroc-Z28
Transmission: auto
cruisin around town the other night, getting a few stoplight to stoplight races, and i screwed something up
i was at a stoplight, with one foot on the brake and the other on the gas, so i could punch the gas right away w/o having the pause from switching my foot from the brake to the gas. anyway, i punched it and i felt/heard a thump from directly under the shifter.
now whenever i punch it at less than 10mph, i hear/feel that thump every time. i can go WOT after i get to 10mph and everything's fine, but if i accelerate fast from a stop it thumps.
sometimes when i hit second at WOT i'll feel a little jerk and the rear end feels a little shaky.
any idea what i did?
Old Jul 6, 2004 | 02:27 PM
ede's Avatar
ede
trans mount, replace it with a ES poly mount
Old Jul 6, 2004 | 02:54 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yup sounds like your brake torqueing broke your tranny mount
Old Jul 6, 2004 | 03:27 PM
ljnowell's Avatar
Oh well, thats not too bad man. That will only take a few minutes. In my experience it almost takes longer to put the car on jackstands than it does to replace that.
Old Jul 6, 2004 | 03:28 PM
Car: 1987 Iroc-Z28
Transmission: auto
i thought brake torquing was hitting the gas with the brake depressed? i didnt do that, i just hit the gas and let off the brake at the same time
anyway, so it's the trans mount, huh? well that's good to know, i was hoping i didn't screw up some major internal part
is replacing a tranny mount a diy job for an inexperienced person like me? or am i better off just takin it to a tran shop? any idea what the cost of the part, and hours to replace it would be? thanks
edit: nm, you answered my question while i was typing it
Old Jul 6, 2004 | 03:37 PM
ljnowell's Avatar
Tell you how I do it. I always put the entire car into the air (all 4 corners) but I am a big guy and need the clearance . You will need a small floor jack under there with you. There is one nut in the center of it, take it off. Then put the jack under the tailshft of the trans, jack up until it lifts up some, and then leave it like that. Take the rest of the bolts out of the mount, Remove and replace. No time at all.
Old Jul 6, 2004 | 06:52 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
A poly mount is definately a good idea... I could literally break a stock rubber mount in 15 minutes after installing one. Put in a poly mount and havent broken it after 3 years of abuse.
The one thing you may have trouble with (well I did, on both f-bodies in my yard) is grind the crossmember's middle bolt hole out a little bit with a file. The center bolt that goes through the cross member and into the poly mount never lined up quite right for me. No big deal, just something you might run into
Old Jul 7, 2004 | 11:19 AM
Car: 1987 Iroc-Z28
Transmission: auto
so this is all i need?
http://store.summitracing.com/partde...N=120%20300537
i have exhaust coming in the mail soon, so i guess if you guys say this is the right part, i'll go ahead and order it so i can install it when i have the car jacked up to install the exhaust
Old Jul 7, 2004 | 11:46 AM
THEGENERAL's Avatar
YUP
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
Bigold4x4
Sep 28, 2015 05:21 PM
