th350 crossmember
Car: '84 Z28
Transmission: th2004r
th350 crossmember
i know a lot of people on here must have th350s. i was wondering what kind of crossmember you are using or what you had to do to make it work. thanks
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I went from a 700r4 to a TH350 in my 86 and used the same cross member. I used a 9" tailshaft TH350 and the torque arm mount from B&M and that was it.
Car: '84 Z28
so i guess i can use the same one that i used with the 2004r. the trans is the same length so i can use the same driveshaft too.
Car: `86 SS / `87 SS
The 200-4R mount is further back than the mount on a TH350. In fact, it's in the same place as a TH400.
The 200-4R is the same length as a 200-C and TH350 - short tail.
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
I'm in the middle of my swap, but my stock 82 crossmember for a T-10 4 sp worked, and is the same as the stock 82 crossmember for a 200C tranny.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kammi10
Nov 9, 2015 08:28 PM
tmork454
Sep 29, 2015 06:33 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
