9 bolt austrailian rear ends
Old 07-14-2004, 10:31 PM
CRAZYCHUCK13's Avatar
Car: 91 Z28
Engine: 383-Carb
Transmission: TH400/3500 Stall
are all borg & warner parts inter changeable?i have a 2.77 9 bolt & have a partner that has a 3.23 disc brake rear end complete out of a 87-89 gta.my rear end is a 2.77 out of a 89 iroc,i am trying swap diffs & change gear ratio to 3.73 from precision gear.
both rear ends are posi.my question is will all parts be interchangeable? can any one help?
thanks
chuck
Old 07-14-2004, 11:10 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The posi carriers are different i believe from 2.77 to 3.08 & from 3.23 to 3.73 or numerically higher.If you only want to change the ring & pinion.Youll have to go with the 3.23 diff.Or change the entire carrier from your 2.77.Everything else should be the same.
Old 07-14-2004, 11:31 PM
IEatRice4dinner's Avatar
Car: IROC-Z
Engine: L98 350/ 5.7L
all 9-bolt parts have to be used with 9-bolt parts, nothing from a 10bolt will work. the 3.23 is not a stock 9-bolt ratio... the stock 9-bolt ratios are 2.77 3.27 3.45.
Old 07-16-2004, 03:33 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
parts
crazychuck13, do you have any extra 9 bolt axle shafts? I'm looking for a drivers side axle shaft. Any info would be great.
hectre13
12-11-2023 08:14 AM
sailtexas186548
01-19-2016 12:21 PM
hectre13
08-26-2015 08:17 AM
Jlanz55
08-17-2015 07:15 AM
1992 Trans Am
08-08-2015 08:16 PM
Quick Reply: 9 bolt austrailian rear ends
