Rearend Problem symptoms???
Old Jul 19, 2004 | 12:55 AM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
ok so i think something is wrong with my rear end.
when i had the rear in the air i was spinnin the wheels and it would get to a point and kinda become harder to turn (not like hard, but it gave more resistance) then made a clunk and then turned super easy.
i have a non posi 2.73 (not sure what bolt 10 i think) rear.
it acts a lil funny while drivin sometimes, i dont hear grinding but it acts werid, idk how to explain it thou.
so if i have to change the rearend i got a few questions:
-will a 4th gen rear fit?
-would a 9 inch fit/or be hard to make fit? (my uncle has one)
any other info would be appeciated, thanks.
Old Jul 19, 2004 | 11:37 AM
Borsty's Avatar
Car: 89 Trans am
no one wants to help me ,
Old Jul 19, 2004 | 12:02 PM
JA_Formula_89's Avatar
Car: 89 Formula
Engine: 5.0 TPI (F-Code)
Transmission: 5 Speed Manual
Could someone have converted your rear to Posi before you purchased it?
Do you notice any issues while driving or when you spin the rear directly from the driveshaft?
Old Jul 19, 2004 | 10:24 PM
Borsty's Avatar
Car: 89 Trans am
no its a open diff, no doubt.
my dad checked it out and i topped it off with gear fuild. he said i was just imagining things/being paranoid
Old Jul 19, 2004 | 10:50 PM
bad ass 85 ta's Avatar
A 4th gen rear is a direct replacement. you will have to deal with your rear tires sticking out like 2 inches farther on either side. not a problem if you use 4th gen wheels and spacers on the front. A 9 bolt is a lot of work to make fit, unless you purchase a custom one made to fit.
Old Jul 19, 2004 | 10:54 PM
Actually I'm stupid. I thought you meant 9 inch Ford rear. A 9 bolt is a direct replacment.
Old Jul 20, 2004 | 03:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: Rearend Problem symptoms???
I'm pretty sure I had that happen to me. Was the transmission in Park? Try putting the rear in the air and spinning the tires again, but first, put the trans in neutral. Then there should be no clunk, and everything should turn super-easy. (The clunk was the open diff fighting the driveshaft, which gets locked in place when the trans is in Park.)
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
