Unknown Rearend problem
Old Jul 26, 2004 | 12:05 AM
Randel '86's Avatar
Car: '89 IROC-Z
I just got finish replacing an axel on the passenger side rear of my GM 12 bolt and upon test driving you can hear a horrible rubbing sound that seems to only be rubbing in one spot, kinda a woosh whoosh sound that gets faster as vehicle speed increases. After removing the brake drum when I was doing the axel swap I noticed on the shoes did not stay flat against the backing like the other one did. Also I noticed that the bolts that hold the brake housing to the axel housing simply spin and seem to possibly be stripped. I was also foolish enough to trust my own natural torque wrench when I torqued down the brackets that go over the bearings in the differential. Not to mention I am missing a lug on the new axel.
The axel needed replacement from hitting a curb, hard, sideways and it was definately bent when I pulled it out. The wheel does not pitch like it used to.
What do you guys think is wrong with my rear-end? The brakes, or the differential? The sound seems to come from the passenger side rear wheel.
Old Jul 26, 2004 | 04:30 AM
ede's Avatar
ede
why don't you fix the shoes, fix the missing stud, and fix the stripped bolts. last 12 bolt i had apart didn't have any brackets holding the bearings in, neither did every 12 bolt i ever seen. as for the noise i think you'd be way ahead jacking the car up and taking a look where you think the noise is coming from.
Old Jul 30, 2004 | 03:17 AM
Randel '86's Avatar
Car: '89 IROC-Z
It was the shoe, replaced the stud, and now it runs like a bat outta hell
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
