Analog calibration box
Old Jul 29, 2004 | 05:31 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
I put 3.73 gears in my 1989 5-speed Camaro, didn't realize the speedo gears are way inside the transmission. Is there a company online that will make a correction box for me?
Old Jul 30, 2004 | 04:57 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Analog calibration box
It'll cost more than the gears. While there are ratio adapters, it would take more than one to correct a decent change (like going from 3.23 to 3.73) and it would just get rather ridiculous.
Email me if you need those gears for your 3.73s though.
-Matthew
Old Jul 30, 2004 | 09:51 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
I've already installed the gears in my 9-bolt, and was looking for a speedometer calibration box... I already had the internal speedometer drive gears, just didn't want to dive into the trans until next spring.
Old Jul 31, 2004 | 12:49 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You have a cable driven speedo so if you use a recalibration box it will only fix the speed the ECM see’s and not your speedo, if you want to fix your speedo you going to have to change the gears or you could waste a ton of money and buy a converter box, a vss, and a cable drive unit.
Old Jul 31, 2004 | 01:10 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, a ratio adapter would work with both the VSS and the speedometer.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
