wrong flywheel??HELLP
Car: 91 rs
Engine: 250
Axle/Gears: stock??
ok i did just see the other one just like this post but please post a reply. i just bought a manual setup form a guy and well 2 weeks later i'm putting the fly wheel on which would be today. but i got 3 fly wheels in the deal 2 are the same. Thier bigger then my bell housing or just roungly fit in the bell housing but not enought to be the right ones. i also got on thats a lil smaller and the bolt hole patter is smaller then what i got on my crank shaft. i'm also assuming the probalme is because the guy before me put a 350 in the car.but is it possible he could put a 400 crank in. and thats why the bigger flywheels would bolt up but don't. or am i just f'd. but i also have incountered every problame while doing this swap. so noting is really extramly bad news
Car: `86 SS / `87 SS
from what I gather, you have two 168 tooth flywheels and one 153 tooth flywheels that fits an 86+ engine. An 85-older engine will have a larger bolt pattern than 86+
None of your flywheels will work with what you've got. All you need is a flywheel ordered for a 1984 Camaro 305 application. That is what's proper for an 85-older 350.
Car: 91 rs
Engine: 250
Axle/Gears: stock??
it's an 86 350 i figured this out when i had to get my carb rebuilt after hard work i figured it's a 86 qjet carb on the stock engien so what would i need
If you have a flywheel with a smaller bolt pattern than the crank in your 350, then I don't think it's an 86 350.
If you got no fly wheel on its easy to tell if its pre 86 or if its post 86 one has a one peice rear main seal the other is a two peice rear main. Just look at it. If it has a bunch of bolts around the outside of the crank where the flywheel bolts on its 86 and on. If not its pre 86. It looks like a big ring that comes off around the crank. Then you can deside which flywheel you need. I have one of both just so I can swap in older engines.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Originally posted by ridecamro
well y not
well y not
Car: 91 rs
Engine: 250
Axle/Gears: stock??
well i have the reipts the guy ahd kept them and i asked for them is says"sbc 350 rebuild 1200$" so i think it's a 350 and 84 was a tbi not a carb plus things look slightly newer i'm gonna chekc that out thanks
Car: 1986 Z28
Engine: 305...350/383 in progress
Transmission: 700r4...fresh rebuild
Originally posted by thegeneral
84 should have been a carb not the other way around
sory 84 z28 HO chilton says tbi but your porbally right
it was all original when i bought it and then we blew the engine so in went the 350 also check out https://www.thirdgen.org/newdesign/tech/techdb.shtml
it has it listed there also that the 84 z28 HO was a carb not a tbi.....
Car: 91 rs
Engine: 250
Axle/Gears: stock??
ok sorry guys.... i'm not the brighteset when it comes to what was stock scince i never had the stock engien....it's not the stock engien thier ethier..... 305 was a lil to small for my likeing so i bought one with a 350 in it. but yeah i'm still f'd on this whole flywheel. i cna't find one. any one know were i can find a fly wheel clutch and pressure plate deal
you could find a bell housing from a older chevy that will fit around your fly wheel ... if you go back far enough you can find some that are cast iron ( a little heavy but strong ) ... although there may be clearance issuses ... then you can run a 12 in clutch disc if the fly wheel will accept it ... good luck ... tao
85-down
86-up
If it's 85-down, order a flywheel for an 84 Z28 5spd.
If it's 86-up, order a flywheel for an 88 Z28 V8 5spd.
monte87cortez
Sep 26, 2015 08:10 PM
