B&M Relay....blowing.
Old Aug 3, 2004 | 10:34 PM
89Kicker_IROC-Z's Avatar
Car: 89' IROC-Z
Engine: HSR B2L 350ci w/LT4 hotcam and AFR 195's
Transmission: Transgo'd 700R w/Yank 2800
Axle/Gears: 9 Bolt, 3.45
Alright guys, for the first time in over a year, my relay blew.
So i went to radioshack and bought another one, POP it went.
I mean it will work for the first few cranks, then after a while it goes.
(everything is wired right)
Only thing ive changed electronically in the car has been my new ignition, coil, wires, cap, rotor etc. I did do a engine overhaul with new heads, cam, and stealthram but that has nothing to do with why its blowing on me.
I bought another one tonight and the car wouldnt even crank over with this little bugger, and the longer i held down the key, the more smoke would start to develop on the relay.
if I hold it down for more than 5 seconds its gonna blow like the one that did yesterday.
question is....
CAN I USE A HIGHER AMP RELAY?
possibly a 10 amp, or even a 30amp automotive relay instead of this crappy little 5 amper?
I mean it worked fine for over a year, and now i go to star the car with the new engine and this keeps happening to me, I dont want to keep wasting 10 bucks on every damn relay just to watch it go bang everytime i try to start the car.
Old Aug 3, 2004 | 11:00 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It has been posted on here recently that a 30 AMP'er works better.
Old Aug 3, 2004 | 11:08 PM
Car: 89' IROC-Z
this one should work better right? (radioshack image)
Old Aug 3, 2004 | 11:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is the link that I was referring to earlier and it has a picture of the relay.
https://www.thirdgen.org/techbb2/sho...hreadid=251586
Old Aug 3, 2004 | 11:28 PM
Car: 89' IROC-Z
yes, thats the standard 5 amp one from radio shack...the same one thats burning out with me.
one quick thing, im using a thin gauge wire for all my connections, could that be contributing to the problem?
Old Aug 3, 2004 | 11:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Thicker is better, but if it was a problem the wires would probably be burning up instead of the relay.
Old Aug 3, 2004 | 11:41 PM
Car: 89' IROC-Z
im gonna try a 10 or 30 amp relay, with some nice gauge wires to match...soder everything on and tape it all and hope for the best
Old Aug 4, 2004 | 10:58 AM
z92maroman's Avatar
Car: 92 Camaro RS t-top
Engine: 305, 434 in the works
Transmission: 700R4, t56 2 come
This relay worked for over a yr, rite? and now even a new 1 smokes immediately? The relay isn't the prob! you have another issue here. Somewhere one of these wires is shorted or something. Going to a higher relay may work, but all u r doing is making the wires take a higher load than they should. thats why the 5A relay to begin with, to protect the circuits! A bigger relay is playin w/fire, LITERALLY!!!!!fire
Old Aug 4, 2004 | 11:49 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I prefer to use fuses to protect my circuits, rather than relays.
