Bolt-In 6-speed ??!
Old Aug 5, 2004 | 09:03 PM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
Bolt-In 6-speed ??!
i just heard that someone makes a 6-speed transmission that will bolt up exaclty where the T-5 used to be, and you can order it with your own gear ratios!! doesn't anyone know anything abuot this? if so i say SCROOO the T-56.
Old Aug 5, 2004 | 09:52 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
how much $$$
Old Aug 8, 2004 | 04:18 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
hum??? a t-56 still but was made to replace the t-5. it's mentioned in the t56 swap sticky (you only need to shorten the drive shaft If I remember) nothing new
Old Aug 8, 2004 | 05:40 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
having done the t56 swap on my own car...
how is it not a direct bolt up?
Old Aug 8, 2004 | 10:03 PM
Engine: 5.8Ltr 356
From what i read you have to change the whole clutch assembly, and shorten the driveshaft. i don't really consider that bolt in, ESPECIALLY having to convert the clutch. and i don't know of any driveshaft shops around here. but shortening then re-balanceing a driveshaft sounds like it could be expensive to me.
Old Aug 8, 2004 | 10:16 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
i used a stock everything to do mine. no shortening of anything.
car was an auto so we just had to mount a pedal assembly. but the transmission bolts right up to the engine and the DS and torque arm work fine. i dunno, it was plain as day to me.
Old Aug 8, 2004 | 10:22 PM
Engine: 5.8Ltr 356
wow i had no idea it was so simple. i was under the impression it involved cutting a bigger hole for your shifter, and fabricating/buying a new crossmember. how much did you get the T-56 for with everything included?
Old Aug 8, 2004 | 10:38 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
well yeah you do have to buy a new crossmember, but thats 2 bolts which bolt right in soo it does just bolt right up i paid alot for mine, i got it a while back. Ive seen people getting killer deals on them lately though. shop around. my car was an automatic so Im not sure aobut making the hole bigger, i actually had to cut a hole since there was none to start with.
good luck! it really was a worthwhile swap
deracer
Apr 11, 2016 12:04 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
BBSDesigns
Aug 11, 2015 07:39 PM
CamaroX84
Jun 25, 2001 01:26 AM
