Aug 7, 2004 | 12:49 PM
Anyone using synthetic gear oil in there 9 Bolt? Have you had any problems since using it?
Reply 0
Aug 10, 2004 | 07:39 PM
9Bolt lube
I am a novice here so take it as it is....but I have heard from several knowledgable people than one should only use GM lube with the posi addittive only...Again I'm not the expert here...Ed.
Reply 0
Aug 10, 2004 | 07:41 PM
9Bolt lube
I am a novice here so take it as it is....but I have heard from several knowledgeable people than one should only use GM lube with the posi addittive only...Again I'm not the expert here...Ed.
Reply 0
Aug 11, 2004 | 10:01 PM
I use olive oil. Extra virgin on track days...:lala:
Reply 0
Aug 12, 2004 | 12:38 AM
Olive oil for a 9bolt?
Now this is strange....any body else heard of this...I have only heard to use GM with additive only...Any other comments???
Reply 0
Aug 12, 2004 | 12:40 AM
i think he is kidding
Reply 0
Aug 12, 2004 | 01:45 AM
olive oil
I also think he's kidding...Olive oil would boil and cook....gees what a gooey mess.
Reply 0
Aug 12, 2004 | 06:57 AM
I don't have a 9-bolt, but I used Mobil 1 with GM posi additive.
JamesC
Reply 0
Aug 12, 2004 | 08:10 AM
Quote:
Do I use a french fry additive?
Reply 0
Aug 12, 2004 | 08:22 AM
Reply 0
Aug 12, 2004 | 02:00 PM
Strange oils
Strange but true...Back in the days of 49 Merc Flat Heads, 49 Caddys etc...we used to run Castor Oil (From the castor bean). Then it was the best racing oil one could get. Guarranteed everyone could tell you were using it from the smell...
Reply 0
Aug 12, 2004 | 02:09 PM
ATF used to be made from sperm whale oil too.
Reply 0
Aug 12, 2004 | 04:42 PM
I was kidding about the extra virgin. But i do know a few people who use various oils. I know seasme seed oil (spelling?) could be mixed with another oil to create good oil.
To answer your question. A few buddies of mine run bimmers. They report when switcing to lucas synthetic oils they noticed improved performace. They've been running it for about a year or so now with no problems. And problems should arise within a year if they're gonna be a problem, cause these arnt small cars (540's) and they have plenty of power. More then enough to blow a rear end if need be. (one kids got 360 hp to the rear wheels)
Personally i wouldn't use it in my Nine Bolt. I say run the cheap stuff with some additive. Once you rebuild her, or get a 12 or 9" use the nice stuff from new. Better yet ask moser or simliar if they will see a performance increase. Or if it will void any warrenty they have. Good luck trying to blow that rear end.
Reply 0
Subscribe
