Stupid/odd question. Dimensions of a 700-R4?
Old Aug 8, 2004 | 11:50 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
From the bottom of the pan to the top of the 'bell housing', what is the hight of a 700-R4? 16 - 17 in high? Reason I ask is I was planning on pulling the trans seperatly from the motor to rebuild it (ungghhh) but I dont know if Ill be able to get the car high enough for it to clear with my cheap jack and stands. Maybe Ill just pull the motor and trans together...
Old Aug 12, 2004 | 11:33 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.tciauto.com/tech_info/trans_dims.htm
Doesn't give the exact dimension you're after, but it won't be more than the width of the bellhousing.
Old Aug 12, 2004 | 12:17 PM
ljnowell's Avatar
i learned the hard way how tough it can be to do that. I know a lot of people that take big hydraulic jacks, and jack the rear end of the car as high as they can, then slide the trans under from the backside, and under the car. then you sit the back end back down on the jackstands. it will work, but it is a PITA
Old Aug 12, 2004 | 04:46 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I took it out last night and managed to just bearly squeak it out the side by taking the front drivers side tire off. Had to tilt it on end and slowly rock it out... Man what a pain...
Old Aug 12, 2004 | 07:52 PM
ljnowell's Avatar
damn. Good job though. sometimes these cars can be a real PITA to work on, but its rewarding to always do your own work.
Old Aug 12, 2004 | 08:48 PM
Car: 88 Camaro SC
Engine: SFI'd 350
heh... now I jsut have to figure out what to put in its place, or possibly rebuild it. Donno about doing a rebuild, though.
ZZ3Astro
Aug 13, 2019 12:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Ian Irvine
Sep 4, 2015 08:08 AM
