TV cable to Holley linkage
Old Aug 11, 2004 | 04:49 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I'm replacing my TBI with a Holley and I'm wondering what sort of results I might expect if I connect the TV cable to the lower hole of the Holley linkage.
I've looked at a couple of sites that contain info on that, and the description of correct geometry for the TV setup is actually with the cable connection being about 1/8" closer to the throttle shaft and slightly further back as well.
So in other words, the Holley location is close but not perfect.
I'm planning to use a pressure gauge to set the TV cable as per the bowtie overdrives instructions.
There's a kit to correct the geometry but it's not cheap. I just thought I'd ask and find out whether the kit is actually nessecary or not.
Old Aug 11, 2004 | 04:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
As long as it looks like this you should be fine.
<img src="http://www3.telus.net/~crussel/tv_geometry1.gif">
<img src="http://www3.telus.net/~crussel/tv_geometry2.gif">
There's no point using a pressure gauge to adjust the stock TV. You could use it to verify that it's working correctly though.
Old Aug 11, 2004 | 04:54 PM
Car: '85 IROC
Engine: LB9
That's one of the diagrams I was referring to in my question.
The Holley linkage places the hole about 1/8" further away from the throttle shaft centerline than what's described there.
Old Aug 13, 2004 | 11:35 AM
Car: '85 IROC
Engine: LB9
TTT
Nobody is using the stock Holley linkage with the 700R4 TV cable???
I don't believe that
Old Aug 14, 2004 | 09:40 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I really wanna know why the hell Holley hasn't made any kind of adapter to work with thirdgen cars. It'd imagine more people use them in thirdgen TBIs than what their original intent is for.
Old Aug 14, 2004 | 02:32 PM
Car: '85 IROC
Engine: LB9
No kidding!
The adapter that Bowtie Overdrives sells looks interesting but it's more than I need, since it comes with a bracket, and I have that piece already.
And they want $100+ for it too.
I like the concept of timing the TV valve opening point with the throttle blade opening, it seems to make sense.
But if you set it up that way with the Holley linkage, the cable runs out of travel before the carb is at WOT.
Old Aug 14, 2004 | 05:03 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Go here: www.transmissioncenter.net
Scroll down to #28.. I think that is what you need. I forget who makes it though (but you can get it through them)..
Old Aug 14, 2004 | 05:27 PM
Car: '85 IROC
Engine: LB9
Sweet!
I was just about to go to the store to buy a piece of steel to build my own bracket, now I don't have to.
Thanks Bro
wigmobile
Feb 26, 2025 02:56 PM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
Magman
Sep 14, 2015 01:30 AM
