700R4 Front Pump R&R
Old Aug 16, 2004 | 09:24 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I did a search on this and couldn't find my answer, so here goes.
Tranny went out, I've been told its probably the pump.
My car needs a new engine anyhow so I pulled the motor and while I'm in there, I take out the converter and remove all the pump bolts for a look.
I can't get the pump to budge!
I don't want to bust anything by beating on it with a hammer.
What should I do to remove this thing?
Old Aug 16, 2004 | 09:40 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You can get a special tool to remove the front pump... The largest section of splines closest to the pump is part of the pump base so that will come out with the pump (stator shaft, iirc). You can get creative and pull it with a gear puller and a c-clamp, but you're better off just getting the tool.
Old Aug 16, 2004 | 11:04 PM
Car: '85 IROC
Engine: LB9
OK Thanks
Someone on another thread said something about renting one of those tools, I'll have to see if I can locate one.
Something else... There's a little star shaped thing pressed into the ID of the front shaft, I assume that I'll want to avoid damaging that. Should I try to remove that? Or should I rig something up to protect it?
If I can't find a tool for rent, do I just center the puller on the longest (center) shaft and press there and pull on the outer shaft?
Old Aug 17, 2004 | 07:53 PM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
www.700raptor.com sells pump pullers. I hope this helps. Maybe you can stop by a local tranny shop and ask if they could just pull it out for you.
Old Aug 17, 2004 | 08:11 PM
Car: '85 IROC
Engine: LB9
I think I'll clamp a 2x4 on each side of the shaft with some holes drilled into them and get some threaded rod that's long enough to reach my harmonic balancer puller, and give that a try tonight.
Just seeing a pic of the puller is helpful, it tells me that there's prabably not a lot of force needed to take it off.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
formula_novice
Aug 18, 2015 08:48 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
