New SLP clutch arrived today...DISSAPOINTMENT!!
Old Aug 18, 2004 | 05:16 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
My new T-56/SLP clutch arrived today. I chosethe SLP because:
1. I have read numerous complaints on here about the Centerforce/T-56 having squeeky throw out bearings. I don't need that.
2. I have read numerous comlaints on there about the RAM HD clutch disk exploding. That's what my stocker did. I don't need that either.
3. That pretty much leaves the SLP.
So it showed up, and I eagerly tore into the box to see my sweet new clutch, and there is was, cast right into the pressure plate... VALEO. BOOO, SLP!! Boo. Stamped on the disk is; "GM". The thing is a stock frickin clutch! There are holes drilled in the pressure plate, I assume to reduce rotating inertia, but other than that, it appears to be a stock replacement. Grrrr.
-Tom
Old Aug 18, 2004 | 05:53 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
that is what they tell you! I think everyone that uses that presure plate has to use valeo (it is there desighn) the only way around this is to change it (centerforce)
Even if you go to auto zone you still get the same thing
Old Aug 18, 2004 | 06:02 PM
Engine: LT1, L400
yeah, O.K., I'm starting to cool down a little bit. I noticed on Tony89GTA's post of his McLeod Twin Disc, it says VALEO on that thing too!
Old Aug 18, 2004 | 06:37 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
The SLP clutch setup is nothing more than a stock clutch disc and I believe a LT4 Pressure plate. You should have gone with a SPEC clutch. All pressure plates will read Valeo, any aftermarket t-56 pressure plate is just a modified Valeo design.
Old Aug 19, 2004 | 01:57 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: New SLP clutch arrived today...DISSAPOINTMENT!!
-Tom
I felt the same way when I first opened up the box for my SPEC clutch! But from what I hear on the camaroZ28 website your SLP clutch isn't a bad one.
On clutch choices for a t-56, me personally from my experience and from a lot of other people with 4th gens I would stay away from any SPEC clutch, just way to many people with problems with them.
Old Aug 19, 2004 | 02:08 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
what ever you do don't buy a Hayes, mines got about 1500 miles on it and when I'm at the track and I do a nice burnouts to warm up the drag radials its slips real bad going into 3rd and 4th..
Old Aug 19, 2004 | 08:00 PM
pasky's Avatar
Re: Re: New SLP clutch arrived today...DISSAPOINTMENT!!
Spec Stage III Carbon clutch here, not a damn thing wrong with about 700 miles on it and clutch chatter is gone. I think the problems you hear about are from the inexperienced. The real problems that do happen, I gaurantee you spec asks to send the clutch so they can inspect and it almost always replace it for free and ship to you for free. They have great customer service.
Old Aug 19, 2004 | 10:22 PM
Tony89GTA's Avatar
Car: 89 GTA
Re: Re: Re: New SLP clutch arrived today...DISSAPOINTMENT!!
700 miles is not a lot to be judging your clutch on just yet. You should have went with a stage 4 if your going with SPEC, one of the main problems with the new stage 3 is they put 4 cylinder springs in your disk hub and they tend to explode. The stage 4 is a solid hub and was the clutch I was originally going to go with but I had enough fun replacing clutches, 2 SPEC's is enough so I figure I'll try the McCloud street twin, from what I hear it's last clutch you'll ever need!! I hope that is true
I have to agree on one thing, they do have excellent customer service.
Old Aug 19, 2004 | 11:35 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Mcleod Single Disk here, 30k miles and still going strong with the Lt4 pressure plate.
Old Aug 20, 2004 | 11:20 AM
pasky's Avatar
Re: Re: Re: Re: New SLP clutch arrived today...DISSAPOINTMENT!!
I just meant to say the chatter stopped after 700 miles.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
mfp189
Sep 27, 2015 09:25 AM
