what speed should trans go into 3rd?
Old Aug 30, 2004 | 07:31 PM
IroczInOz's Avatar
At what speed should the transmission go into 3rd gear on a T700R4 under real light acceleration basically just touching the gas pedal.
Mine goes into 3rd at 20mph is that about normal? Or does it seem a bit low?
Old Aug 30, 2004 | 09:52 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
It kinda depends on what gearing you have but my car with 2.73 and less than 2k rpms while accelerating will shift to 3 around there.
Old Aug 31, 2004 | 12:40 AM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Irocn, with 3.27's my transmission will shift into 3rd by 20mph if I am being extremily gentle with the throttle. I mean the barest of touch. Going WOT it'll hold to 4,500rpm, or about 60mph in 2nd gear before shifting into 3rd.
All of this will change depending on what rear gears you have. Transmission affects it too, but we know you have a 700r4 in there.
Dank hound, your 91 RS doesn't happen to be blue does it?
Old Aug 31, 2004 | 08:12 AM
IroczInOz's Avatar
FRUITYONE: i have 3.23 so it seems pretty much the same as what you experience. Mine will also hold till 4500 rpm when at WOT.
I was just worried that after I did my trans service the shifts seem softer for some reason. So I was just checking if all is okay. I have adjusted the TV cable.
Old Aug 31, 2004 | 05:19 PM
dankhound's Avatar
Car: 91 RS
Teal green with a dent the size of a mail box in the left fender.
Old Aug 31, 2004 | 09:05 PM
FruityOne's Avatar
Do you live on Prarie? I pass by a 91 RS every day on my way to work. I'm not exactly sure of the cars color.
Old Sep 1, 2004 | 12:49 PM
dankhound's Avatar
Car: 91 RS
Thats not me the only way you can see my car is if you have x-ray vision, or i happen to be out and about.
Old Sep 2, 2004 | 01:13 AM
FruityOne's Avatar
Darn, oh well.
If you happen to ever see a white 89 GTA with a crack in the front bumper cover be sure to beep. Thats me.
Oh yeah, it'll sound like a beast. No cats, headers, cammed, port work, flowmaster muffler (yuck!)......
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
jbd1969
Aug 17, 2015 07:06 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
