megashifter question
Old Sep 5, 2004 | 07:44 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
i installed my new 700 today. no major problems until i started megashifter install. i bolted it in and put the indicator in but when i tried to shift it will not go into r or p. it ratchets fine until then.
the trigger seem stuck also. it will not move at all. the cable is not hooked up yet if that makes a difference. am i missing some kind of adjustment?
since my car doesnt have a computer will i
have to do any wiring hookups except backup lights?
Old Sep 5, 2004 | 08:15 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
did you adjust the cable underneath the car like it says to do in the instructions?
Old Sep 5, 2004 | 08:20 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
i havent installed the cable to the tranny yet. i have never owned an auto trans before so im kinda learning as i go.
Old Sep 5, 2004 | 08:42 PM
the only time the trigger will work is when you are in drive or neutral to go into reverse or park....I think..I cant remember...and I have one........LOL
Old Sep 5, 2004 | 08:49 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
its in neutral now but the trigger will not move. ill take another look at it in the morning. it was the last thing i started working on and after 12 hours of rolling around on rocks
i could have missed something.
Old Sep 5, 2004 | 09:05 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The trigger will not work in neutral.. Here's some scenarios that should explain proper operation:
Shifter is in park. Pull trigger and shift to drive. Now you can pull the trigger to go to reverse, neutral or park. Lets say you go to reverse from drive. To go to drive, you don't have to pull the trigger, you can just pull it down into drive (it will stop at drive).. Pull the trigger and shift to park.
Shifter is in park, pull trigger to go to drive. Ratchet one down to 3. Trigger will not function. In order to go back to park you first have to ratchet up one to drive, then pull the trigger and up to park you go. If you pull the trigger from park and go to neutral, you can pull the trigger and go to park or reverse or drive.
That said, you can't pull the trigger from neutral if you ratcheted there from drive. You have to ratchet back to drive in order to pull the trigger and go back to park.
Hope this helped..
Old Sep 6, 2004 | 06:15 AM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
yes it did thanks
Old Sep 6, 2004 | 10:59 PM
kd5boc's Avatar
Car: 92 RS
wow I've owned one for months and you just confused th &@($ out of me! You could have just said it will only come up in OD and Park.
LMAO
Hope this helped..
Old Sep 7, 2004 | 10:37 PM
chevydude350ho's Avatar
Car: 90 Iroc-Z
Engine: carb'd 350
Transmission: built 700r4/3000 stall
You forgot that the trigger will also lift up in reverse
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
