super t-10 + L98???
Old Sep 6, 2004 | 02:17 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
super t-10 + L98???
I have access to a freshly rebuilt super t-10 4 speed and was wondering what i would be getting my self into if i wanted to put this into my car (mind you i have already weighed out all the pros and cons im talking more about what im getting into trying to install it).
I have the 700-R4 in now so id have to do a full auto-manual swap anyways. What major problems could i run into? The guy im getting it from is pretty certain that the bellhousing will bolt up fine to my engine and that all i would need is the flywheel off of a t-5 car.
I am aware that i would also need a new driveshaft.
Old Sep 6, 2004 | 03:32 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Re: super t-10 + L98???
too much of a headache dont do it....i wish i didnt do my conversion only mines more expensive im doin a t-56 swap
Old Sep 6, 2004 | 04:14 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
and if you are gonna do it, do it for something more than a Super T10. they are cool when you are doing a period-correct resto on a 2nd gen or an EARLY 3rd, but not on a car as new as yours. get a T56 or AT LEAST a WCT5
JMHO
Josh
Old Sep 6, 2004 | 10:20 AM
ljnowell's Avatar
I think the 4 speed is cool, gives it a real muscle car feel.
Old Sep 6, 2004 | 12:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The BH will bolt to the motor, no problem.
Where you will have trouble, is with the clutch fork hitting the floor pan, if the BH you have isn't from a 82 T-10 V8 Camaro or Firebird. You won't be able to massage the floor pan right there, because it's right where your gas pedal goes.
You'll need the BH out of a 82 4-speed car, and the linkage and pedal assembly from that car; and some drive shaft work of course; and some sort of provision for the torque arm.
All in all, it's not an easy swap, unless you have a whole 82 T-10 car as a donor.
Old Sep 6, 2004 | 01:09 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Re: Re: super t-10 + L98???
LoL what youre talking about is an auto-manual swap period which yes is a bitch but i plan on doing regardless, and most people say the t-56 goes in pretty easy.
The reason i want to use the t-10 is im not worried about the no od and i just like the idea of a 4 speed. Also i can get the tranny bellhousing hydros clutch, all brand new/freshly rebuilt for 1000 dollars canadian and i need a new tranny cause mines shot anyways.
Rb83 thanks i thought there might be something like that to cause problems.
Old Sep 6, 2004 | 01:14 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
get the t-56, overdrive is a nessesity nowadays, we don't live in the days where gas is 20 cents a gallon
Old Sep 6, 2004 | 01:21 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
I'm sorry this is one of my biggest pet peeves even though i do catch my self doing it once in a while.
I asked what troubles im going to have putting it in and even mentioned that ive already weighed out the pro's and con's of this transmission. My car barely ever see's the highway so having overdrive is not much of an issue. Ive already decided not to do it though because of the difficulty i would have had.
Old Sep 6, 2004 | 07:27 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
Re: Re: Re: super t-10 + L98???
well its not as simple as everyone says...alot of tools that you need...and not to mention...make sure you have like
5 days off in a row to do this swap...i put in 2 or 3 and its not enough....
all the parts list is not correct...they take things for granted... a new write up will be on its way.
Old Sep 7, 2004 | 07:07 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
porkyzilla, It really is not that hard. I did a t-5 swap years ago and that was before I ever worked in a shop. it only took a afternoon. besides putting in the pedals it was just like doing a clutch and flywheel job. the t-56 was not that differant. same thing but, I used the sophn t-56 torque arm which is more complicated (has to be adjusted) even that was not bad. if you can replace a clutch then 90% is easy going the hardest part of it all is cutting the firewall in the right spot.
Old Sep 7, 2004 | 09:41 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Re: Re: Re: super t-10 + L98???
And yet some of us have completed auto > T56 in one night, go figure.
Old Sep 7, 2004 | 10:53 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Doug, not sure if you decided against the swap just on troubles with the clutch setup, but heres something to consider if you'd still like to do it, Lakewood offers a bellhousing for our cars, setup for the hyd clutch, if im not mistaken the T10 will bolt right up to it, allowing you to use a hydraulic clutch eliminating the linkage problem, and use spohns crossmember / torque arm to mount it up.
Old Sep 8, 2004 | 01:22 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
I like this idea. I honestly have a limited amount of experience with this but have some people who will be able to help me out if i tackle this. The guy i would be getting the trans from is a buddy so hell help me sort all of this out.
FormulasOnly
Jul 23, 2018 08:47 AM
no green
Jan 9, 2016 09:22 PM
Zell1luk
Sep 29, 2015 10:36 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
