t-5 help
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
t-5 help
Where is the fill plug on my t-5 trans? Is it on the passanger side above the drain plug, or is it on the drivers side. Help
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yeah, it is easier to pour it in the top where the shifter mounts, but he'll still have to pull the fill plug on the passenger's side (the upper one, the lower one is the drain plug) so he can fill it to the right level.
Car: 89 RS
Engine: 383 in building process
Originally posted by scubas_90rs
what is the plug on the drivers side used for?
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
that plug holds the 5th/reverse rail in place...
fill it up thrugh the shifter with 3 quarts..no need to remove the fill plug
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
thanks for letting me know what it is. i seen it when i was putting the trans in the car i figured that it was important so i didn't screw with it.
luvofjah
Sep 26, 2015 08:28 PM
