wont upshift 1-2 and 2-3 at WOT
Old Sep 7, 2004 | 10:58 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
well just had all my leaks fixed, and now while driving with my new tranny, it was feeling fine, chirping into second etc.. but later in the day i noticed it wasnt shifting from 1st to 2nd or even from 2nd to 3rd anymore from wot, it would up**** with anything less then WOT. what went wrong?
Old Apr 15, 2006 | 04:24 PM
tomc1500's Avatar
Car: GMC c1500 stepside 1989
Engine: 350TBI
i have also this problem now.
with WOT my tranny won't upshift 1-2 and 2-3.
at 5900rpm i stepp off the pedal because it still would not shift.
any one?
Old Apr 15, 2006 | 11:44 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
its been so long since this problem occured for me im sorry i cant tell you what fixed it or what happened. im on my third 700r4 though now since then if thats any consolidation.
Old May 12, 2006 | 01:30 PM
copperhead110's Avatar
I also have a subset of this problem.
My 700R4 won't shift into 3rd at WOT.
This causes a problem at the dragstrip for my little 305. I start creaping past the redline just before the finish line.
The above is the only problem my tranny has. It does have aabout 180k on it.
Old May 12, 2006 | 04:41 PM
83crossfireta's Avatar
Adjusting your TV (throtle valve) cable may fix that. It will affect your shift points at lower throttle also, so be careful not to adjust much, one or two clicks might do it.
Old May 13, 2006 | 06:27 PM
1989iroc5.7's Avatar
Car: 89 iroc
Engine: 5.7
Axle/Gears: 3:73
mine does it on the 2-3 shift i have to let off to get it to shift and its not the tv cable. im going to try another valve body to try and fix it cus it seems nobody on the site knows what causes it or how to fix it.
Old May 13, 2006 | 08:08 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Sound's like you've got a gummed up governor. Shift points are controlled by a combination of TV cable position and a signal from the governor. At WOT the shifts are controlled by the gov..Pull it out and make sure that it moves freely and the springs haven't broken or fallen out of it. Pulling the valve body without diagnosing the problems will only lead to more headaches.
junior419
Apr 7, 2025 11:35 AM
Pac J
May 17, 2020 10:44 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Damon
Sep 26, 2015 04:29 PM
HikoriYami
Sep 21, 2015 07:11 PM
