Tranny shot
Old Sep 9, 2004 | 07:23 AM
m300slr's Avatar
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
Tranny shot
I just lost 4th gear today. It has been causing me trouble now for about half a year, sliping in and out. I think it finaly went. So I was wondering how difficult of a job is it to change out the trans. Could I do it in a day. Also, what are some good rebuilt trans to buy (700R4).
Thanks,
Rob
Old Sep 9, 2004 | 08:41 AM
ljnowell's Avatar
You can change out a trans in an afternoon. 6 bell housing bolts, 3 tq converter bolts, 4 trans crossmember bolts, trans mount bolt, undo Lines and TV cable, swap. Oh yeah, the dustshield too, but that is common sense.
Old Sep 9, 2004 | 03:20 PM
m300slr's Avatar
Car: 1985 Z28
Cool that was the answer I wanted to hear.
Thanks,
Rob
Old Sep 9, 2004 | 07:33 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
I just had my tranny out this last weekend. Remember a few things:
Make sure you put the torque arm bracket (long bolts that go through tail house) on the new transmission before lifting it into place, or you'll have to pull the tranny again.
Cut a slot in the hole for the dipstick tube to allow it to slide onto the already started bolt.
Route the dipstick before bolting up the trans.
Use a 1/2" crows foot to do the cooler lines along with a swivel.
Use about 2.5 FEET of extensions for the bellhousing bolts - and tilt the engine back some to get the top ones.
Support the engine with a jack and a block of wood on the pan.
Locktite the flexplate to the torque converter and torque to 35 ft.-lbs.
If the new trans is empty, it'll take about 9 qts of fluid.
It's a good idea to do the U-joints now.
Make sure the torque converter is seated into the pump.
Adjust the TV cable when done and filled, and do it again after a short drive (and disconnect it at the Throttle body bracket completely before starting).
Oh, and do it all on a lift with a tranny jack to save a couple hours.
Enjoy!
Old Sep 10, 2004 | 07:46 AM
m300slr's Avatar
Car: 1985 Z28
Do any of you sugest a certain brand of rebuilts, I hear jasper is good, but cost is a big issue for me. would it be just as good to have someone rebuild my current one.
Old Sep 10, 2004 | 08:33 AM
ljnowell's Avatar
If you seriously want a 700 to last, and you plan on putting power to it, nothing but probuilt will do, IMO. Of course, I like th350's better so....
Old Sep 10, 2004 | 06:23 PM
m300slr's Avatar
Car: 1985 Z28
What are the main differences between a th350 and the 700r4.
Old Sep 10, 2004 | 06:53 PM
Th350
1) 3 speed
2) no overdrive
3) higher first gear
4) no TV cable - has kickdown cable and a vacuum modulator instead
5) as far as I know - usually no lockup converter (I think some versions were available with it though but not most performance ones)
6) size and length
7) generally can handle more power
8) not as finicky or easy to break
This should probably be in another thread.
Old Sep 11, 2004 | 09:45 AM
m300slr's Avatar
Car: 1985 Z28
Well,
I can get a jasper trans for $1300.00 I think they list for 1700.00. Or I might just have mine rebuilt. But I guess the only thing to look at is Spend probably 600-700 on a rebuild of my trans, or get the jasper which includes a tourqe converter.
Mirror Image
Oct 29, 2017 09:51 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
JSDaddy189
Sep 26, 2015 03:50 PM
IROCZ1989
Sep 4, 2015 11:54 AM
