700r4 problems
Old Sep 11, 2004 | 05:37 PM
madmax57's Avatar
700r4 problems
at the track with a fresh 700r4.,,, 2000 street stall l/up converter and a megashifter....couldnt get trans to shift out of low at under 6500..usually about 6700-7000......way to high..i would shift it manually and it wont shift..all other shifts were ok..i moved cable about a 1/16 at a tiime from the original spot it never changed..also i dont have the lock up hooked up yet how can i test it to see if it will lock up?..i just want to make sure that it does..i will hook it up later...any ideas..this trans was rebuilt by a good builder..hes kinda scratching his head a bit on the phone..thanks
Old Sep 11, 2004 | 10:13 PM
kd5boc's Avatar
Car: 92 RS
Re: 700r4 problems
Not sure about the 1-2 shift...almost sounds like a govenor problem, but your other shifts are fine....hmmm could be some kind of blockage from your govenor to the 1-2 valve...not sending enough pressure to the valev to make it shift.
Being in a third gen, you can short pins A&F on your connector under your dash and your TCC should lock up in 2-4, unless the rebuilder changed that.
Find our what your builder did to it and let us know.
Old Sep 11, 2004 | 11:23 PM
kptkid's Avatar
if you jump those pins what kind of effect does it do to the way it runs?
Old Sep 12, 2004 | 01:43 AM
kd5boc's Avatar
Car: 92 RS
Nothing...it will act like a standard transmission...you can "feel" it as far as the way it accellerates.
But DON'T leave it that way!
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
