Keep on breaking tranny mounts
Old Sep 14, 2004 | 08:52 PM
dnovotny's Avatar
I've replaced my broken stock one with:
1) ES with spacer plate, broke mount after a couple thousand miles. Large wear marks where tranny mount bolts to cross-member.
2) ES without spacer plate, used new tranny cross-member, no more wear marks. Replaced because of groaning/squeeking noise from underneath, but it didn't break.
3) Stock rubber mount, broke within a thousand miles.
4) Prothane mount and tranny mount, was quiet for a couple of days. Now squeeks and thumps over speedbumps/road bumps.
Could one or more of my motor mounts be shot? Car has never been in an accident. Need some help to figure out what's causing the mounts to break. Also, when driving over sharp bumps it feels/sounds like the tranny is moving up and down a little bit causing the mount to make noise and eventually break. However, whenever I put my hand on the shifter, even when the mounts were broken, I couldn't feel any movement.
TIA
Old Sep 15, 2004 | 03:16 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Id be checking out the motor mounts...If they are shot then they tranny mount wont last long>>
Old Sep 15, 2004 | 03:27 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
if its an automatic transmission, you wont feel any movement with the shifter because it is no way attached to the transmission, it is bolted to your floorpan.
Old Sep 15, 2004 | 03:59 PM
dnovotny's Avatar
Its an auto. How can I determine whether the motor mounts are shot?
Old Sep 15, 2004 | 05:44 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
lol whatch it go back and forth... jk umm from my experiance any mount with any rip is a bat mount. and should be replaced. i just got a ES urethaine mount. hopefully it woulds well.
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
IROCZ1989
Sep 4, 2015 11:54 AM
Formula_88AE
Sep 3, 2015 01:47 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
