Speedometer drive gears
Old Sep 20, 2004 | 10:14 PM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
I have a 1987 firebird with a 700R4. Can anyone tell what the colors should be for the drive and driven gears in the trans. for the speedometer drive with a 2.73 rear axle ratio. Or maybe the teeth for the drive and driven gears.
Old Sep 20, 2004 | 10:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay, this is out of a 86 firebird GM service manual but should be basically the same as the 87.
Old Sep 21, 2004 | 01:58 AM
Car: 1987 TransAm
This is great! An early 1987 and 1986 are the same. A late 1987 uses an electric speedometer and has a sending unit. The problem is I have a 2.73:1 gear ratio. I know this was the original factory ratio on this axle because I rebuilt it 2 years ago and found a cracked tooth on the pinion gear and replaced with a US Gear set that is 2.73:1. The original gear set said on the side of the ring gear "GM 2.73:1". I know what everybody is going to tell me that the decoder says it should have 3.08:1, but it did not and does not because it is an open road race car. The car presently has 235/60-15 tires and wheels.
Old Sep 21, 2004 | 02:09 AM
Car: 1987 TransAm
Also, 3.077(3.08), 3.273(3.27),3.455(3.45),& 3.727(3.73) are 10 bolt ratios. 3.417(3.40)& 3.70(3.70) are 9 bolt ratios. I have a 10 bolt rear axle.
Old Sep 21, 2004 | 11:26 AM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
my 9 bolt has a 3.08, so the above is incorrect...
Old Sep 21, 2004 | 04:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
To Forshock 85TA,
If you need it, here is the listing for the 85 TA and firebirds. You will notice that there are quite a few more options for the 85 than there are for the 86 models. Does any one need it for the 82 & 84 models?
Old Sep 21, 2004 | 04:09 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Sep 21, 2004 | 04:10 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 3
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
jharrison5
Aug 19, 2015 05:53 PM
