How Much can the T-5 Take?
Old Sep 21, 2004 | 09:06 PM
TonyP455's Avatar
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
How much power can my T-5 Handle?
Old Sep 21, 2004 | 09:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I can't tell too much about yours.
But I can tell you, I shredded about 3 or 4 of them in my 83, while it had the OE L69 in it. The casualty rate went up FAST after I put a 400 in it in about 87 or 88. I think the longest lived one was about 4 months, over a period of about 12 years. Unitl.....
Out of the clear blue, I made the most startling discovery! One day, for no particular reason, I accidentally found out ( can't imagine how it happened ) that it's actually possible, for me to lift my right foot off the floor while shifting gears!
{gasp}
I had no idea that could work, after all those years before I got this car of driving 4-speeds.
After that revelation, the next one I put behind the 400, lasted for about 35,000 miles of that motor, and then another 25,000 behind another 305 that's in the car now. And most amazing of all, it was still working when I took it out.
So, I can draw 2 conclusions from this lesson:
1. One can trash it mercilessly with a 305 at will; and
2. One can make it last behind some real power, if one drives it accordingly.
Again, I can't comment about yours; but that's how it was with mine. But somehow I doubt yours is much different from the piles of smoking debris I accumulated.
Old Sep 21, 2004 | 11:02 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
Excellent...my little 305 car is more of a canyon carver than a drag racer. The WC T5 should last a long, long time.
Old Sep 22, 2004 | 08:46 AM
TonyP455's Avatar
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
Well I was gonna bolt it to a 400, so I guess Ill give it a shot =)
Old Sep 22, 2004 | 08:50 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Mine is behind a 400+ HP 383 SuperRam setup and working fine so far (knock on wood!).
Of course I always use the clutch, don't do real heavy sustained burnouts, and lift the accel when I am driving spiritedly while shifting......
YMMV, of course!
Old Sep 22, 2004 | 10:15 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
My T-5 isn't stock, but so far it's held up well. And that's behind a 408 that pushes 490 TQ and 390 HP at the fly.
But I still don't speed shift, because doing that has the potential to kill any manual gearbox.
Just like anything else, if you treat it right it'll last.
Old Sep 22, 2004 | 10:25 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
if your running a Gforce like your sig says youll have no problem beating the snot out of it....i know guys who are running over 700 ponies on these trannies...and i **** you not they TRY to break it EVERY shift...not one problem...
and there drag cars aswell...full slicks revlimit launches..60;s in the 1.3 range
Old Sep 22, 2004 | 10:27 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
A friend of mine had his WC T5 live behind his 502 that he has in his 84 Z.
the 2 things that saved the tranny were the clutch and tires. One or the either would burn up, therefore keeping the tranny alive.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
