speedo gear t5 question pic inside
Old Sep 25, 2004 | 11:06 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i got a new speedometer gear but it's different then the original one is it still workable? the red one is the new one it's all plastic and a little shorter then the other, the other one is metal except for the gear
Old Sep 25, 2004 | 07:51 PM
Brock's91RS's Avatar
Car: 87 IROC
Engine: mini-rammed 350
Transmission: WC T-5
I'd like to know this too,I have the same situation,I thought I was losing my mind!!
Later
Steve
Old Sep 25, 2004 | 10:53 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I've done several T5 speedo gear swaps for 3.73 rear cars with new GM plastic gears and steel sleeves without a problem. Do it.
Old Sep 26, 2004 | 06:25 AM
Car: 87 IROC
JMD...When you say "steel sleeve" are you talking about a "sleeve" over the plastic shaft of the gear?or the steel sleeve pictured above(the one that goes into the tranny)?
Also...I have 3:73 gears with a T-%
The gear inside(round one) the tailshaft is RED,is there a gear to buy to get correct drive without changing the inner(red) one"
The one i have in the trans now is a grey color
Thanks for any help...I've searched this subject quite a bit,I only seem to get MORE confused...must be old age setting in!
Steve
any part numbers would help too!!
Old Sep 26, 2004 | 09:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, it goes right together. Just put it in and be done with it.
Old Sep 26, 2004 | 09:40 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
thanks RB your so knowledgable
Old Sep 26, 2004 | 09:44 AM
jmd's Avatar
jmd
Steve
Steel sleeve = right hand part in your picture.
Don't EVER trust gear colour. Count teeth. I've seen oddball T5 and 200-4R and 700-R4/TH350 gear colours.
Search through the Tricksters posts. He just recently (last week or so) posted GM speedo gear info with accurate tooth count information. That's the same info I like to reference Every single "gear calculator" on the web is incorrect compared to what GM put in cars. Do the math sometime on one of them with the factory tyre size & gear ratio; you'll see, it's funny but true.
There is no way to get correct speedo gear ratio with the red gear inside the trans. if it's an original GM gear and you have 3.73s. You must change that one.
Old Sep 26, 2004 | 08:20 PM
Car: 87 IROC
Thanks for info..With my luck I knew I would need to replace the inner one!!
Thanks again
Steve
Pac J
May 17, 2020 10:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Jan 28, 2016 08:42 AM
Numbah-1
Oct 2, 2015 08:27 AM
JSDaddy189
Sep 26, 2015 03:50 PM
