4L60E Shifting problems!!
Old Sep 27, 2004 | 06:46 AM
Meen95z's Avatar
Car: 95 Camaro Z28
Engine: 5.7 LT1
I have a 95 Z28 with a 4L60E. Just put a 3000 TCI stall in it. At wide open throttle it will go to about 5200rpm and then free rev until it hits the rev limiter a few times then shift. If i let out just before 5000rpm it will shift ok. What happened? And how can i fix it? Have a trans cooler and fluid is fine!!!
Old Sep 27, 2004 | 02:23 PM
NYIROC's Avatar
Car: 87IROC
Transmission: MAD DOG 700R4 w/3:73 posirear
I'm having a simliar issue with a brand new rebuild. Hope someone can shed light on it.
Regards,
G
Old Sep 28, 2004 | 09:22 AM
Buisson91B4C93Z's Avatar
it sounds as if the detent cable is too tight or your throttle valve is sticking. you may want to try popping the governer out and cleaning it. The last time i had one that wouldn't shift untill i let out of it, it was the govener...
Old Sep 28, 2004 | 01:33 PM
Pro Built Automatics's Avatar
The 1995's were OBD1's, and to resolve this, talk to Ed Wright about this problem.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
dhonda200
Aug 11, 2015 11:50 PM
