Transmission Cooler question
Old Oct 1, 2004 | 06:36 PM
FireBoid's Avatar
Car: 1987 Firebird, 1997 Camaro
Engine: 2.8L, 3.8L
Transmission: T5, 4L60E
I'm installing a cooler on my 700R4, but I don't know which line is the return line. Lines are off right now. Tranny top or bottom, and radiator top or bottom?
Old Oct 1, 2004 | 06:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Bottom line from transmission to cooler, top line from cooler to transmission.
Old Oct 2, 2004 | 05:57 PM
FireBoid's Avatar
Engine: 2.8L, 3.8L
I'm going to series it with the radiator and I want the cooler last in line so I need to know which fitting on the tranny is the return.
Old Oct 2, 2004 | 10:05 PM
onebinky's Avatar
I believe the return line is the upper line, both on the trans and on the radiator.
Old Oct 3, 2004 | 12:55 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Read that as "Bottom line from transmission to factory cooler in the radiator, top line from factory cooler in the radiator to transmission."
Old Oct 3, 2004 | 01:04 AM
onebinky's Avatar
Yup. that's how I did mine and haven't had issue yet.
I've heard that depending on driving style and climate it might be benificial to put the aux cooler on the pressure line instead of the return. Have you heard anything about that before?
Old Oct 3, 2004 | 12:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, but it appears to work for people either way. I almost don't think there's a "wrong" way to do it.
Cleotiz
Jan 6, 2018 08:56 PM
Dialed_In
Aug 20, 2015 01:45 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
