new rear no power
Old Oct 2, 2004 | 12:31 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
new rear no power
Is it possible that when i changed my rear i lost power?
i recently took the non posi rear out of my 85 z28 5 speed i dunno what gears were in there stock and put one in from a 87 firebird posi.
i was told it was 3:23 but i found out they are 2:73.
now with the old rear i used to shift at 5500 easy.
with the new rear it struggles and climbs slowly and it seems my redline is now 42 4500 rpms
could it be cause of the lowwer gears?
thanks
Old Oct 2, 2004 | 02:41 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Your old gears were probably 3.23s, and that's why your car doesn't seem to rev as quick anymore..
Old Oct 2, 2004 | 10:29 PM
onebinky's Avatar
You didn't loose power, but you did loose some torque multiplication. Assuming you had 3.23's before, and you now have 2.73's, you have roughly 18% less torque multiplication to get the car accellerating. If by some chance you had the 3.43's, you are now short about 26% of what you were at.
The good news is that a gear swap is easy, and pretty cheap
EDIT: The swap probably shifted you out of your powerband some too, which is why it feels like it doesn't pull as hard or long.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
86White_T/A305
Aug 17, 2015 12:16 AM
stalkier
Aug 13, 2015 12:59 PM
novaderrik
Aug 10, 2015 12:44 PM
