Att Bobsroc
Old Oct 5, 2004 | 07:24 PM
IroczInOz's Avatar
Att Bobsroc or others Pressure Readings
Seeing as you were one of the few people to help me out with my trans pressure readings. I wanted to ask you what you think of my readings and what the probable cause is with a problem that I think I have.
I have pasted your pressure table here for reference so you can compare it to my values.
Here is what I have, and the gauge needed is 0-300 PSI.
Gear-Min TV///Max TV
P-75-85///166-203
R-100-140///180-340
N-75-85///166-203
O-75-85///166-203
3-75-85///166-203
2-160-245///160-295
1-160-245///160-295
Here are my pressure readings. Note that the table on the far RIGHT was at HIGH Idle 1500RPM with TV cable pulled all the way out.
I am see that my most of my readings at idle and MIN TV are a little lower then yours by about 10PSI but look at 1st and 2nd there is a huge difference.
Something does not look right and I always felt that it had a hard time changing into 3rd from 2nd at WOT unless I backed off a little. Also from a quick test when going at min speed in 2nd then when I floor it, it does not seem to downshift into 1st like it should it just accelerates in 2nd.
What do you think?
Old Oct 6, 2004 | 04:23 PM
IroczInOz's Avatar
I also forgot to ask did the 1986 transmissions that came on the camaro T700R4 have an auxiliary valve body?
A guy I was talking to asked this question as he was not 100% sure but he said that it should have one. I think it was the auxiliray valve body he was talking about?
Old Oct 6, 2004 | 08:31 PM
ede's Avatar
ede
try PM or email
Whata69
Mar 2, 2016 06:34 AM
TraviZ
Northern California
33
Apr 8, 2006 02:28 PM
jawzforlife1
Apr 24, 2003 11:41 PM
ops32
Apr 10, 2002 03:57 PM
WaynesRS
Aug 22, 2001 02:09 PM
