rearend
Old Oct 11, 2004 | 12:02 PM
twincam's Avatar
Car: 92 rs
Engine: 305 tbi
rearend
I was wondering if anyone can tell me if a rearend out of a transam not sure of year but 82 - 92 with ws6 package & rear disc brakes would fit in a 92 rs, stock was 305 if so is there any special parts I would need. Thanks Dave
Old Oct 11, 2004 | 03:05 PM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
The rearend would fit physically in the car but Im not sure what you would need to convert the stock drum brakes rear end in the camaro to the disk brakes on the new rear end, you would probably need a few parts that would usually be needed to do a drum to disk conversion, but on the other hand, you probably have most of the parts on the ws6 rearend anyway, so if you would need to get any additional parts it shouldnt cost that much $
Old Oct 12, 2004 | 12:17 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Itll all bolt right in if you have the brake lines that came with the rear. The proportioning valve may be different. I didnt really find it to be too much of an issue although it and the smaller master cylinder that I have limits the braking force that can be generated.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
