th350 swapped into 1985 iroc
Old Oct 11, 2004 | 08:24 PM
bigmike's Avatar
Car: camaro 1985 iroc
Engine: 350 4bbl
Transmission: th350
HEEELLP! I SWAPPED A TH350 IN PLACE OF TH700 IN MY 85 IROC. I NEED TO LENGTHEN DRIVESHAFT 3.5 IN. OR FIND A CUSTOM TRANS YOKE THAT IS LONGER. I KNOW THE TAILSHAFT/HOUSING FROM TH700 CAN BE SWAPPED OUT...BUT A LITTLE BIT BEYOND MY SKILLS. ANY SUGGESTIONS?
Old Oct 11, 2004 | 09:38 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
the driveshaft needs lengthened 2.92 inches.
You're probably better off just getting the driveshaft retubed than with the other options out there, since you already have the th350 intact.
Old Oct 11, 2004 | 11:13 PM
ljnowell's Avatar
Yeah, like jmd said, its a little late to change the tailshaft, output shaft. You would be better off having your driveshaft redone.
Old Oct 12, 2004 | 06:56 AM
bigarmzz's Avatar
Car: 86 2wd
Axle/Gears: 2:73 open (for now)
besides, you have to take your tranny out, take it apart to change the tailshaft...
thats a bit of a pain in the a*s
-bigarmzz-
Reddeath210
Oct 6, 2015 08:20 AM
Fronzizzle
Aug 17, 2015 02:52 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
