what rear end gear
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
There should be a metal tag that is under one of the rearend cover bolts. that should tell you what you have. Or you could check the RPO codes for your car ( they should be in the center consol or in the trunk on a sticker) and this will tell you what came in the car.
Engine: 305 H.O.
well that sucks! if some one on here has the ability to tell you what rearend gears you have by what you have stated in your first post, then by all means someone give this guy the answer!
The only thing i can tell you do do is pull the cover and see what is stamped on the ring gear. Last edited by -ZERO-; Oct 22, 2004 at 04:05 PM.
you don't really need the program, math is not that bad if you know your exact wheel diameter and the ratio of the 5th gear, I could do it if you give me those numbers.
But your biggest problem is that you have to rely on your gauges to give you an answer. How accurate do you think that speedo or that tech is? You could do the math and come up with something like 3.31, then what?
Best bet is to pull the cover off. It'll take you 15 minutes, you probably need to change the fluid anyway and it'll be a learning experience.
Just pull the diff cover and count the teath. Thats the most acurate way. ring tooth count divided buy pinoin tooth coumt will tell you what gears you have. Its a good exscuse to change the gear lube any way.
Check tech section of thease boards . looks to me if it is a stock rear end it should be 3.23's or 3.73's
Tech section
Tech section
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
