Do torque conveters "go bad" ? Bad vibration.....
Old Oct 24, 2004 | 05:47 PM
wilson1070's Avatar
Car: 1985 Trans Am
Engine: 4 bolt main Chevy 350/330hp
Hello all, I have a problem here that may or may not be trnsmission related.....
My 86 T/A , w/700R4, while either going down the road, or at a stand still , has a BAD vibration fron 1500-2800 RPMs
I sure seems like its balance related.
Car runs & "seems" to shift ok, and I'm just wondering if the TC could "go bad" I guess ?
I guess I could slide the trans back some & slide the TC off & restart it,
Anyone have a similar problem in the past ?
Old Oct 24, 2004 | 06:11 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Yep. Back off the converter & check it.
Old Oct 25, 2004 | 05:28 PM
3gc's Avatar
3gc
Car: Z28
I'm having a very similar problem. I "tested" the TC by going the speed that it occurs in (any speed that the rpms are around 1800-3000 rpm), put it in neutral, shut the engine off, waited a few seconds, turned ignition off to verify the engine was no longer turning. The vibration was still there with the engine off. It got no better, no worse. Doing this stops the torque converter from turning (i assume) so i basically ruled out the TC. However, i still have the vibration in park while reving.
When the TC is removed, how would i go about checking to see if it's good or not?
Old Oct 25, 2004 | 07:24 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Remove your inspection plate. Remove the 3 bolts holding the converter onto the flywheel. Then slide the converter back into the tranny housing. Now start the car and see if the vibration is still present. If its not chances are your converter is the problem.
Old Oct 26, 2004 | 12:07 PM
3gc's Avatar
3gc
Car: Z28
I backced off the converter. The vibration isn't as bad but is still present. Particularly at 2250 RPMS. Should i be looking for a miss or something, bad balancer, Flywheel?
Old Oct 26, 2004 | 01:54 PM
3gc's Avatar
3gc
Car: Z28
Well, the flywheel is warped. I'm guessing that can cause a vibration.
Old Oct 26, 2004 | 02:21 PM
wilson1070's Avatar
Car: 1985 Trans Am
3gc.....
How did you notice the flywhell was warped ? Was it visibly bent ? I'm have the exact problems you are, but this is a bad vibration.
This is a great forum.
Old Oct 26, 2004 | 10:12 PM
3gc's Avatar
3gc
Car: Z28
I put the car on jack stands. Remove the ecm fuse and with the inspection cover off look at the flexplate and have some one crank it over. If it's warpped you could see it wobble.
88rscamar0
Sep 23, 2015 09:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
abray1
Sep 10, 2015 04:53 PM
angel2794
Sep 8, 2015 06:22 PM
