all clutchs go to hell
Old Oct 27, 2004 | 05:30 PM
redlightrunner's Avatar
well. i installed the new slave. but it doesnt feel right at all. now i have about 2 inchs of free play. its a 92 so i cant adjust it. i was wondering if anyone else has this problem. before the slave blew out it felt right on. this sucks
Old Oct 27, 2004 | 09:50 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Bleed it.
Old Oct 29, 2004 | 05:01 AM
how do you properly bleed the camaro clutch?
Old Oct 29, 2004 | 05:19 PM
nsimmons's Avatar
Unbolt it, pump the piston by hand about 200 times while having a helper watch for air bubbles comming out of the top. Add fluid as needed. This is the only thing that worked for me.
Old Oct 29, 2004 | 08:49 PM
see we did it when it was hooked up. but i guess i could try that
Old Oct 30, 2004 | 11:16 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
For the t-5 and t-56 I find that works best is you just need to unbolt the slave and angle it down 45* then push the slave piston in and slowly let it out, keep doing that untell you get no bubbles. Another way to bleed the system for a t-5 setup is there is a bleeder screw on the slave that can be used, just get someone to pump the clutch peddle and hold it and do what you would do for bleading brakes.
Old Oct 30, 2004 | 05:35 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
I gravity bled my 91 RS. Open the bleeder and let it just drip. I also cupped my hand over the top of the master (with a hose) and blew pressure into the master. Just made the process a lil faster. That cured my pedal problem.
Old Oct 31, 2004 | 05:18 AM
ok as long as im not the only one with this pedal problem thanks guys
Old Oct 31, 2004 | 03:47 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
a way to cheat and do this by yourself is as follows
loosen the bleeder valve like you would when bleeding brakes
hook up a vacuume line to the bleed valve
put the other end of the vacuume line into a jar
fill the jar up with fluid enough to cover the vacuume line
go inside the car push the clutch in pull clutch out
repeat last step untill you flushed quite a bit of fluid through the slave system
also make sure you keep a eye out for the fluid level on the clutch slave
but this way you don't need someone to keep tighting and losing the valve
this way when you pull the pedal back up it CAN'T suck in air and instad sucks in a little brake fluid
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
