Pilot Bearing
Old Nov 2, 2004 | 02:41 PM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
Pilot Bearing
I need help asap. How can I get a very f*cked up pilot bearing out. I pulled the trans to look to see what was up with it and the pilot bearing was bad. how do i get it out now. thanks in advance scuba
Old Nov 2, 2004 | 03:41 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
go to autozone, tell them what your doing, you can "rent" the proper tool. then get all your money back when you return it. if you search on this board you will even find pictures of it.
Old Nov 2, 2004 | 04:30 PM
thanks for the info but the closest auto zone is about 200 miles away. i got what was left of it out with a screwdriver and a hammer. What left doesn't even look like a pilot bearing anymore it just looks like peices of brass.
Old Nov 3, 2004 | 08:18 AM
Engine: 5.7, 5.0
How's your T-5 doing?
Old Nov 3, 2004 | 08:54 AM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
pack it full of grease then take a socket or dowel that will just fit into the hole and tap with a hammer. the bearing will fall out.
Old Nov 3, 2004 | 10:24 AM
it is doing fine when i can get the clutch to disengage. why do you ask
Old Nov 3, 2004 | 10:43 AM
Engine: 5.7, 5.0
because it's behind a 350. j/k
I was just curious if the trashed pilot bushing cause any problems. Is the new one in yet? Did you go with a new brass bushing or roller bearing?
Old Nov 3, 2004 | 11:10 AM
yeah i just put in the brass one. I am sort on money right now and the parents bought it fo me so i went the cheap way for now. i think my zbar is fubared. I am just going to have to eather wait for money to buy a new one. or wait till i get the money for a hydolic system.
Old Nov 3, 2004 | 11:55 AM
Engine: 5.7, 5.0
FYI. The roller bearing is only $7.99 at GM parts direct. but you do have to pay shipping.
Old Nov 3, 2004 | 12:03 PM
Thanks for the info on that. but i needed it asap hoping that it would take care of my problem but it didn't. and i am not going to pull the trans again just to put in a roller pilot bearing when i don't need to just yet. the clucth still dosent want to disengage so it is sitting for a little bit longer.
Old Nov 3, 2004 | 02:28 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
did you remove the clutch/flywheel?....did u use an alignment tool to realign the clutch?..
how old are your hydraulics?....how did you install the throwout bearing in the clutch fork?...if the little "clips" on the clutch fork are on the outside of the throwout bearing then thats your problem....theres a pic of it on here...search for "throwout bearing"
Old Nov 4, 2004 | 01:24 AM
f-crazy yes i did remove the clutch but didn't remove the flywheel. yes i used an alinment tool when i put the clutch back on. my clutch system doesn't have any hydraulics. the throw out bearing was installed correctly. The z-bar is shot. i am waiting to get the 140 bucks to go and buy a new one.
Old Nov 5, 2004 | 09:32 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
thatll do it...good luck =)
84LsxZ28
May 17, 2020 02:21 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
