Did I kill it?
Old Nov 2, 2004 | 11:23 PM
ScreaminBird87's Avatar
Car: 87 Firebird
Engine: 2.8
Did I kill it?
alright guyz this is my first post. About a month ago I bough a 87 firebird with a 2.8 in it. couldnt stand it so I built a 350 to put in it. I needed a tranny so a buddy of mine sold me a tranny out of his 85 pick-up it was a 700r4 and he said it had just been rebuilt not to long ago. Still has the nice enamal on the torque converter from rebuild. Well I got the motor and tranny put in. and drove the car for maybe 1 1/2-2 days for about a tottal of 3-4 hrs. Well the I diddnt know the need of the tv cable except for downshiffting. so it wasnt hooked up cuz the carb wouldnt accept it. Well tonite the tranny shifts in to 1-2 flawlessly but 2-3 requires some high RPM's and she wont go into 4th now. Did I kill it. or is it possible i can hook up the tv and it will still be okay? this really sucks ive had my 3rd gen on the road w/ the new motor for 1 1/2 days and i already killed it.
Old Nov 3, 2004 | 07:33 AM
Car: 87 Firebird
Engine: 2.8
btt
Old Nov 3, 2004 | 08:04 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: Did I kill it?
well as you have found out you definatly need the tv cable hooked up it does more than downshift the transmission its nothing like the older transmissions out there totally different animal......
now im not going to tell you that your tranny will be okay because id be lying not knowing 100% either way .....
what you need to do is hook it up the proper way and adjust it the proper way and then try to drive the car and see what happens...
Old Nov 3, 2004 | 11:50 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I had one break on me. Fixed it and the trans was fine after that so theres the possibility that its ok. Jsut dont use the car untill you hook teh tv cable up. Also remember to set it so its nice and tight at full throttle.
Old Nov 3, 2004 | 10:13 PM
Sporkinator's Avatar
Car: 85 IROC
Engine: GMPP350HO
Transmission: BEEFED 700r4
Food for thought...
I switched to a carburated engine in my car that used to be a TPI set up, and with my 700R4 I needed to purchase a torque converter lockup kit for 4th gear. If you have a locking converter, I would HIGHLY reccomend it. Not a difficult install, and you might as well throw in a shift kit while youre at it (another easy install).
corey8084
Sep 17, 2015 02:56 PM
InfinityShade
Sep 5, 2015 06:38 PM
FireDemonSiC
Sep 3, 2015 12:31 PM
solocus
Sep 2, 2015 12:14 PM
InfinityShade
Aug 22, 2015 08:00 PM
