700R4 question???
Old Nov 15, 2004 | 05:52 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
700R4 question???
Im going to get my tranny rebuilt... im also going to put an B&M shift kit in there. I have a stock 305 TBI... would it be a good idea to put a high stall troque converter on there??? after i do that im going to get 3.73 gears or maybe 4.11..
Old Nov 15, 2004 | 07:01 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
I used the Trans-Go shift kit when I rebuilt my tranny, it worked great. Available from Summit Racing, about $130 though. Unless you plan on adding a cam that would require a high stall converter, I wouldent go that rout. There are some stall converters that offer a stall speed somewhat higher than stock. These offer quicker acceleration, higher cruising speeds, and in some cases better gas milage.
~Max
Old Nov 16, 2004 | 10:00 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
so max, you think i should get a smaller stall converter??? i was checking to see when my converter locked up. it lockes up around 1500 rpm.. so will the smaller converter Lock up qicker??? thanks alot bro!!
Old Nov 19, 2004 | 01:21 AM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
Ramair21,
Since I live pretty close(sacramento) give me a call at 916-974-7664. I can help you out. I can tell you the ups and downs of different stalls on TC. I have also used and installed shift kits so I know which one works better.
Bennie C.
Old Nov 19, 2004 | 01:29 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
I agree with max, if you a have a stock tbi motor I wouldn't be thinking about higher stall converter just yet. Put that money towards a better cam, intake etc. in order to get that tbi making power past 4000rpm then you can start looking into higher stall and gears based on the engine's response to those mods.
Old Nov 19, 2004 | 10:29 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
yeah your right. i was just curious. i was doing some research and im going to do that corvette servo on my tranny. i was talkin to this guy yesterday and he was given me some good tips on that. he also did it too. and he said that he felt a really big change a really BIG ONE!! i just ordered yesterday off ebay. a 1TUF92Z i think im going to give you a call soon. is the Transgo shift kit the way to go??
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
