Shift light
Old Nov 23, 2004 | 04:14 PM
1986camarojoe's Avatar
Car: Z28
Engine: 310
Shift light
Alright I have a 91 camaro RS with the 700r4. I had it in 1st gear at a stop sign and did a little burnout and shifted into 2nd at about 4000 rpm. Then I put it into OD when I got out on the highway, the car seems to shift fine but at 2000 rpm a light comes on, on my tach that says "shift" with an arrow above it. So I was a little worried about this and took a little drive. It goes thru all the gears just fine but this light keeps flashing soo I'm a little worried that maybe I broke something. Whats going on??
Old Nov 23, 2004 | 04:22 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Has the car always had a auto transmission?
If it is an auto car it should not even have the bulb in the cluster. When an auto trany TC locks it would cause the shift light to come on.
At least as far as I know...
Old Nov 23, 2004 | 04:25 PM
Car: Z28
Engine: 310
Yea it's always been an auto. Last night I replaced all the lights in my dash because the speedo light was out. I noticed there was some bulbs missing so I figured somebody took them out. I put bulbs in all the empty holes. Is this what it is??
Old Nov 23, 2004 | 10:04 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Thats it. All you need to do is take out the shift light bulb out.
Kevin
Old Nov 24, 2004 | 12:16 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yeah, I actually believe on the 700R4 it's indicating when the torque converter is engaged, but don't quote me on that.....
LittleFranks
Sep 17, 2015 12:22 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
