in need of clutch
Old Nov 28, 2004 | 09:44 AM
fake formula's Avatar
Car: 1986 z28 camaro
Engine: 305 4bbl
Transmission: t-5
in need of clutch
Im kind of in a struggle for cash (due to recent car accident) , and my clutch is starting to slip when I get on the throttle real hard, what would be the best way to handle this problem in my situation? what would be the cheapest clutch, that is worth putting in my car? Also, I have never changed a clutch before, and I know it is very involved. I have friends that have done it that could be of help. Would I be better off crawling under and doing it in my garage, or taking it to the shop? Any input is greatly appreciated.
Old Nov 28, 2004 | 06:05 PM
xanax's Avatar
best way, dont get on the throttle hard if you dont have the money to fix it.
Old Nov 29, 2004 | 02:20 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i agree with that.
Old Nov 29, 2004 | 02:31 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
when i blew my luthc i jus replaced it with a zoom oem replacement it work ok if u dont have any real engine mods i was $120 at auto zone and only took em about 4 hrs to install start to finish its as easy as dropping the trans and sawp really not that diffucult but u might want to have the flywheel turned while ur at it
Old Dec 3, 2004 | 08:55 PM
Engine: 305 4bbl
Transmission: t-5
how much did it cost to be installed?
Old Dec 3, 2004 | 10:49 PM
Car: 87 Formula
Engine: 350 tpi
i dunno i installed it myslef in about 4 hours in the driveway coulda his it done in 3 but proplr tend to stop over when im workin otuside lol
also that was for the whole kit including clutch, pressure plate, and throwout bearing it will prolly be alot chaeper for just a clutch
Old Dec 4, 2004 | 01:36 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
It harder with an 8 but I drove 6-8 months with a "bad" clutch. I just had to float it to move at a reasonable speed. also if it does slip while moving, ya gotta lift n get back in it like a drag racer slipping the tires.
It just take prastic.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
