Vrooom.....bam
Old Dec 4, 2004 | 01:23 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
Vrooom.....bam
well, the title about says it. when i step on the gas, then let off semi-quickly, it makes a clunking noise, like something under the car jumped up then dropped. at first i thought it was the sway bar cause one side was missing the bushings, so now that's replaced and it still does it. what is the problem?
Old Dec 4, 2004 | 01:30 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: Vrooom.....bam
check the transmission mount first then look at the engine mounts
Old Dec 4, 2004 | 01:44 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Re: Re: Vrooom.....bam
do it..... do it.
Old Dec 4, 2004 | 02:29 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
If the sound is coming from underneath the shifter,or around that area,then it is the tranny mount. Easy fix
Old Dec 4, 2004 | 03:32 PM
Car: '94 Z28
Engine: LT1 350
whew, nothing major, i'll check that and see if i can tighten it. hopefully that's it.
Old Dec 4, 2004 | 06:06 PM
BadBowtie88's Avatar
I doubt you can "tighten" it. If it is indeed your tranny mount, you will just have to replace it. Which is still an easy fix. I have replaced one on the '88 I used to own, and one on my '89. Seems to be a common prob with those things breaking. Then again, they are just rubber that do nothing but get older and weaker everyday.
Old Dec 4, 2004 | 06:29 PM
91Zman's Avatar
Car: 1991 Z28
Yeah once your tranny mount goes it's gone,there's no re-tighten.
Old Dec 4, 2004 | 06:52 PM
CaysE's Avatar
One of the bolts could have worked loose. Happened to me. The second time, the mount was sheered in half. Polyurethane all the way.
Old Dec 4, 2004 | 08:55 PM
Car: '94 Z28
Engine: LT1 350
dang, i need to check it tomorrow when i have day light, and does anyone have like a guide to replacing it? i really don't wanna break anything on my tranny or that area.
Old Dec 4, 2004 | 11:56 PM
CaysE's Avatar
I'm assuming it's a 700-R4 trans. Jack up the car and put it on stands in the front. Get under the car and unbolt the trans mount. Jack up the trans a bit to get the mount out, put on the new one, drop the trans back down, bolt to torque specs, enjoy.
Old Dec 5, 2004 | 10:50 AM
Car: '94 Z28
Engine: LT1 350
its an automatic on an 83, so probly yes, never had any problems with my tranny before so i never bothered to look.
Old Dec 5, 2004 | 01:48 PM
91RSHawaii's Avatar
Car: 1999 30th Anniversary Pontiac T/A
could be your torque arm bushing, when mine was shot, it made that sound when i got on it and let off to fast... but then again it did that whenever is shifted gears too. but that was on a manual t-5... dont know about 700-r4s..
Old Dec 5, 2004 | 03:30 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
check the torque arm bushing and tranny mount, could be either of them
Old Dec 6, 2004 | 03:04 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Lost the nut off mine the other day...darndest thing...
new nut... mount was OK...& I was on my way!
Old Dec 6, 2004 | 03:47 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
trans mount ill bet very simple to replace but get the energy suspension poly urethane one youll break rubber ones over and over...jack up the car on stands, than raise your jack to support the trans on the tail shaft or in a sutiable place than unbolt your cross member and your mount, replace mount bolt up cross member if your very lost i have pics for you and a write up i did
Old Dec 6, 2004 | 04:37 AM
red88fmroula's Avatar
Car: 1988 formula
Engine: 5.7 l98
Transmission: a4
would a bad tranny mount also make a sound like the driveshaft is hitting the floorboards...the noise is really close to the middle of the tunnel
Old Dec 6, 2004 | 11:47 AM
CaysE's Avatar
Exactly.
Old Dec 6, 2004 | 02:37 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
more or less its gonna be your trans hitting the trans tunnel....when i broke mine i didnt change it for like 2 weeks and well ill show you pics of my tunnel if i can find it
Old Dec 6, 2004 | 03:50 PM
Car: '94 Z28
Engine: LT1 350
ouch, hope i didn't do anything to the bottom of my car then. maybe i should get that fixed before i drive it anymore....
Old Dec 6, 2004 | 06:56 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
just drive it softly and you will be fine.
Also, if its the mount on the transmission x-member, I recommend getting a energy suspension poly mount. They have a metal part inside the mount that keeps it from seperating. I replaced mine twice with the stock mount and broke them withing a week, went the the poly one and it works great.
Old Dec 6, 2004 | 09:04 PM
Car: '94 Z28
Engine: LT1 350
ok, so i gotta get a poly tranny mount, i tried looking some prices up on it, but i can't find squat on tranny mounts, little help on that...
Old Dec 6, 2004 | 10:26 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
www.jegs.com.
PN# 355-3-1108R
$21.99
This is such a no-brainer mod/repair/upgrade that it should be manditory for TGO membership. (J/K )
Seriously, this is easy; easier than changing the oil. There's only one GM Rear Drive trans mount for all of the chassis/trannny combos so there's no guess work. Once the car is up on jacks/ramps, this is a 10 minute job at most. Most cases, it's old bolts out, new bolts in, wheels down, you're done. Some people, myself included have found that the new crossmember bolts are larger than the old ones, and have to drill/grind the slot in the crossmember. This should take you about 42 seconds with your Black&Decker to accomplish.
This is not a job to be scared of. Even this guy can do it -->:lala:
Old Dec 8, 2004 | 12:44 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
if it was the tranny mount that snapped, shoudlnt the shifter be bouncing up and down? maybe its diff. in an auto, but when i snapped my tranny mount in the summer, the shifter was going all over the place
but ya, get a polyeurothane one. that will never break
Old Dec 8, 2004 | 01:09 PM
wrightz28's Avatar
Car: '88 GTA,'85 z28
Engine: L98, LB9
Transmission: 700 r4
Axle/Gears: sleepy 3.23, hello 3.73
No, it wouldn't move. It's not a physical portion of the trans like a manual shifter. An auto shifter is connected to the trans via cable.
Old Dec 8, 2004 | 02:43 PM
91Zman's Avatar
Car: 1991 Z28
Not sure exactly if this is how the shifter mechanism is but The tranny mount is located on that brace on the tail of the tranny by the driveshaft i.e. since the auto shifter uses a cable(vs a rod on manuals) to a bracket, the shifter doesn't move(with a busted mount) when you nail the gas.
Old Dec 9, 2004 | 04:41 PM
Trust me, the shifter doesn't move. Like I said before, I've replaced two of them and that's not what happens. And red88fmroula was right on the money on how it sounds. SpeedCat also hit the money on how hard, or how easy I should say this job is. And indeed sometimes the new bolts are bigger, but again, easy fix. Let us know how you fair.
Old Dec 30, 2004 | 08:14 PM
Car: 1988 formula
Engine: 5.7 l98
Transmission: a4
old post but decided to let you guys know the tranny mount was good but there was no bolts holding it in stupid previous owner and the emergency brake cable hanger dropped down and wore a groove in my ds
Old Dec 30, 2004 | 08:56 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
what it was just laying on the ds and wore into it?
Old Dec 30, 2004 | 09:09 PM
CaysE's Avatar
Happened on my 84 SC. Just get the cable fixed. The DS is probably fine.
Old Dec 31, 2004 | 04:05 AM
HaroGt14's Avatar
Don't worry about it . . . in 3 months I went through 3 Tranny mounts. Don't know why, but I don't care since it's getting a Turbo 400!
HaroGt14's Avatar
Double Post.
Old Dec 31, 2004 | 08:42 PM
Car: 1988 formula
Engine: 5.7 l98
Transmission: a4
yea pulled the ds and threw an lt1 in nice difference shes in the shop again getting the front end rebuilt
