How do you know your rear...
Old Dec 6, 2004 | 01:50 PM
Lampropeltis's Avatar
Car: '89 Flame red metallic GTA!!
I am not quite sure if the GTA I have came with the 3.23 or 2.77 rear gears. I am inclined to say the 3.23 as at 80 mph it is up to about 2700 rpms, though I am not sure. I am also unsure of what differential was placed from the factory on F-body's in the late 80's. In changing the diff gasket last week, I noticed it was a 9 bolt and on the inside it had the letters BW (which I am assuming stands for Borg-Warner whom I thought only made trannys and the occassional movie too . I believe I saw the #'s 3.23 on there as well. Was this the stock unit? Any info will help.
Peace,
Old Dec 7, 2004 | 04:46 AM
ede's Avatar
ede
gm used 9 and 10 bolt rears, does it really matter what it left the factory with as much as what's in it now? count teeth and do the math and you'll know what you have.
Old Dec 7, 2004 | 02:34 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Sounds like you've got 3.23's. I've got a 2.77 9-bolt and 80 mph comes at an even 2000 rpm.
It probably was the stock unit, and the stock gearing. If you 've got disk brakes, you've got a pretty good axle there.
Old Dec 7, 2004 | 02:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If I remember correctly, the 10-bolt has 3.23's, the 9-bolt 3.27's.
JamesC
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
Dead Reckon
Feb 4, 2012 09:35 PM
88fastgta
Dec 20, 2011 07:25 PM
imRICH23
Brakes
Nov 20, 2011 08:44 PM
MrDude_1
May 18, 2004 08:00 AM
