Cold car...no shifting!!!
Old Dec 5, 2004 | 10:48 PM
Gr89RS's Avatar
Car: '02 Z06
Ok when my car isnt warmed up it sometimes won't go into firt gear when im at a light..i try to put it into gear and i hear a whining/grinding sound.then when the car is warm it is fine....what isgoing on guys????
Old Dec 6, 2004 | 08:43 PM
Gr89RS's Avatar
Car: '02 Z06
Come on guys youve been able to answer all my other questions...
Old Dec 7, 2004 | 12:39 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Are you using auto tranny fluid in this T-5? You should be.
Try changing the fluid, maybe it's thickened up from being old and dirty. Other than that, you might have some badly worn synchros....
Old Dec 7, 2004 | 03:46 PM
Gr89RS's Avatar
Car: '02 Z06
Thanks,why should i use auto tranny fluid??o and why would it only do this when the car is cold??O and how much do syncros cost??
Old Dec 7, 2004 | 04:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The T5 is meant to use ATF in it. Its what GM puts in them.
Id let your car warm up for a min or two before you take off. If ya got thick [butt] 80-90 it needs a min to get the thick honey moving and it won't want to shift or go in gear as easy warm.
Just hold the rpms around 2000+ for a min n netural. that will get the goo moving.
Old Dec 7, 2004 | 04:16 PM
Gr89RS's Avatar
Car: '02 Z06
Well istead of getting the goo moving, wouldn't just replacing the fluid be a simpler solution???
Old Dec 7, 2004 | 05:22 PM
vernw's Avatar
You use auto tranny fluid because that's what GM says to use in the WC T-5 trannies. Have you put in something else?
Old Dec 7, 2004 | 05:24 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
give this a shot, it worked for me
next time it gives you a hard time going into first, try pumping your clutch a couple of times, then try it. My dad's 91 t/a sometimes has that problem, and this method seems to take care of it.
Old Dec 7, 2004 | 05:32 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well yea, but unless your out side right now changing it, I bet your gonna drive it a few more times before you get it changed.
junior419
Apr 7, 2025 11:35 AM
92firebirdguy
Sep 1, 2016 07:53 AM
armac
Sep 29, 2015 07:06 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
58mark
Sep 21, 2015 07:21 PM
