So are us guys with newer cars screwed?
Old Nov 29, 2004 | 02:10 PM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
I've done an extensive search, but returned with little. Therefore I bow to the transmission gurus for assistance. :hail:
I am building a carbed 383 right now for my 1992 RS. The 92 is currently equipt with a 305 TBI and a shift-kitted 700R4. My power goals for the new motor are between 400-500 NA horsepower.
1) Will I be alright swaping out my 700R4 with a TH-350? If later on down the road I decide that I want to throw a 100 shot on it for kicks, is it do-able? (I honestly could care less about N20, i'm just curious)
2) The only thing really scaring me about this whole swap is my gauge cluster. All the 1992's have electronically controlled gauges (correct me if i'm wrong) so what do I do when I put in the new trans? What are my options?
While we're on the topic, what do I do about the tach?
Old Nov 29, 2004 | 07:32 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
ud either have to run mechanical or run adapters a a t350 will handle upwards of 500 chp or 450rwhp i believe im runnin one on the elco now and it served well for 2 yrs and my mtr is only pushin 400rwhp it is sllippin tho
Old Nov 29, 2004 | 09:05 PM
1981z28's Avatar
about your cluster it will work fine i have seen it a 100 times.but you need to take the bulb out of the service engine light because after your swap it wont go off.
Old Nov 29, 2004 | 09:14 PM
Engine: 5.0L TPI
Axle/Gears: 3.08
So how do I make the cluster work with the new transmission??
Old Nov 30, 2004 | 06:57 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: =--
WHAT? No, leave the light in. There is a converter out there some where to use your dash with a cable drive output. But don't just take the light out. You computer is telling you that it has no VSS input.
Old Nov 30, 2004 | 06:40 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Maybe just buy the correct VSS and put it on your TH350 ?
Old Nov 30, 2004 | 07:33 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Also, the fact that you're changing from TBI to carb, your "SES" light will come on.
The whole purpose of the computer is to regulate the amout of fuel going into the engine. (richer, or leaner) So if you go up or down in altitute, or your carb isn't perfectly calibrated to where you live, your O2 sensor will see a rich, (or lean) condition, and try to adjust by leaning (or enrichening) at the injectors. But if there are no injectors, and the mixture doesn't change, then the computer will throw a code. Then you'll have an "SES" light. It won't matter if you pull the bulb, until the smog police come after you.
Old Dec 7, 2004 | 05:59 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
A little off topic, but where did you get those blackouts for the headlights, I've been looking for some.
1992 Trans Am
May 10, 2023 07:19 PM
camaro71633
Sep 1, 2015 10:24 AM
86IROC112
Aug 17, 2015 02:00 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
